What are the best used speakers for around 13K?
0 Members and 1 Guest are viewing this topic. Read 22493 times.
Geardaddy
Re: What are the best used speakers for around 13K?
« Reply #60 on: 17 Jun 2008, 02:12 pm »
I recommend the Delta Summits from Intuitive Design.  They combine electrostatic speed and transparency with box speaker dynamism and will match or better the speakers mentioned above.  The Deltas use a first order crossover which equals sonic purity to me.  They are not that fussy in regards to room placement which translates into real world useability.  They are worth a look.aa
« Last Edit: 17 Jun 2008, 03:16 pm by Geardaddy »
Marbles
« Reply #61 on: 17 Jun 2008, 02:16 pm »
I recommend the Delta Summits from Intuitive Design.  They combine electrostatic speed and transparency with box speaker dynamism and will match or better the speakers mentioned above.  The Deltas use a first order crossover which means sonic purity to me.  They are not that fussy in regards to room placement which means real world useability.  They are worth a look.aa
Have you heard the Sason's?  If so, where?  Thanks
TomS
« Reply #62 on: 17 Jun 2008, 02:48 pm »
Nice looking speaker and from all the reviews it sounds like an awesome deal for $8500. MAybe someone has them in the NY area???
Mike
If you make it to Chicago some time, Robert's place is close, just a few miles from Bob at SP.  Some amazing speakers in the cornfields here :)
Big Red Machine
« Reply #63 on: 17 Jun 2008, 02:51 pm »
Mike
Beware of Children of the corn!
Marbles
« Reply #64 on: 17 Jun 2008, 02:53 pm »
Mike
Ted_b has both the SP Tech speakers and Sason's..both from the same small burb in those cornfields.
I have not heard the SP Techs, so can't comment on them.
Maybe Ted can comment on both of those speakers.
mcullinan
« Reply #65 on: 17 Jun 2008, 03:19 pm »
Yeah what is it with those people in the middle of nowhere???? I guess cause you could hear a pin drop in the bumblewoods... lol.
Some kind of talent is a brewin!
Mike
TomS
« Reply #66 on: 17 Jun 2008, 03:23 pm »
Mike
I think it has something to do with being willing to work for next to nuthin' because you love it :lol:
jhm731
« Reply #67 on: 17 Jun 2008, 08:44 pm »
Listen to the PMC OB1i or EB1i.
mcullinan
« Reply #68 on: 17 Jun 2008, 08:54 pm »
I heard the previous incarnation, amazing bass. Too much bass on the OB1, I dont think he had it set up right, no room treatments I could see and this was a dealer. The rest of the spectrum was ok, though Im sure its improved with the new line. I also heard a larger version from there pro series Holy Jesus! Great for home theater, though would never fit in my space.
Mike
Imperial
  • Love keeps us in the air, when we ought to fall.
« Reply #69 on: 17 Jun 2008, 09:13 pm »
I'm thinking: What exactly is it that you feel is missing, or must change
with the sound of your system?
Or is this just a case of upgrade-itis ?
Coz... replacing a pair of Merlins... is not easy to do!!!
A BAM would improve them. But create more bass issues in the making.
One could get a Behringer unit and use it's dsp and room correction facilities to really work
wonders... you place it between the drive and the dac and rock on!!!
A skilled dsp-artist... (I guess you would be that then - pushing the buttons and all..) can really change the sonics of a system with
this type of unit. That is a viable option here, I should think!
You could add them Holograph  tri-forks or whatever, behind the speakers.
I know that you got something called Svano miljoteknik helmholz resonators - bass absorbers in the US now
those are superb at notching out bass problems, it all comes down to ... I feel - I might be off here by a mile but I'd rather just say it:
You know the Merlin's - Make them work!  :|  Waddabout' it?
Imperial
mcullinan
« Reply #70 on: 17 Jun 2008, 10:37 pm »
They are my first great speaker, should I stop at that, idk. I need to hear more, so maybe its upgrade a tight is!!
Im looking for a live there sound. Maybe the Merlins are the best idk.
Mike
tvyankee
« Reply #71 on: 17 Jun 2008, 11:12 pm »
hey
take a look at these.  http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1218896011
this really is a very good speaker and it looks great on top of it.
good luck!
bacobits1
« Reply #72 on: 17 Jun 2008, 11:30 pm »
Check out Gallo Reference 3.1 and pocket 10G.
Marty DeWolf praised them in this issue of BFS.
D
Mariusz
« Reply #73 on: 18 Jun 2008, 02:35 am »
If I may suggest a pair or two.
Vandersteen 5A - shouldn't  be all that difficult to overcome some problems associated with the room's acoustic properties and optimal speakers placement.
and
Classic Audio Reproductions (horns) - easy to drive . great all around performer. However , my experience is limited to the brief audition during T.H.E Show . I only wished that I could spend more time with them and/or audition them home in my room and with familiar gear.
The rest of the budget - room treatments and records
Cheers
Mariusz
jhm731
« Reply #74 on: 18 Jun 2008, 05:42 am »
Mike
If you've got problems with space and room interactions this is your speaker:
http://www.gradient.fi/models/helsinki
superchad
« Reply #75 on: 20 Jun 2008, 04:46 am »
I would say Vandersteen 5A without a doubt a bargain at $13K.
doug s.
  • makin' music
« Reply #76 on: 20 Jun 2008, 07:34 pm »
i have never heard these, but i owned their smaller brothers, & in their own right, they'd sound great in your room.  but, if you are trying to unload s'more money, these would get you half way to your budget limit!   :green:
http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1219171996
doug s.
mfsoa
« Reply #77 on: 24 Jun 2008, 02:24 pm »
Here ya go, Mike.
Von Schweikerts ready for pickup from NYC:
http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1216350570
-Mike
macrojack
« Reply #78 on: 24 Jun 2008, 03:41 pm »
You can have my speakers for $13K and at that price I'll deliver them.
WGH
