What are the best used speakers for around 13K?
0 Members and 1 Guest are viewing this topic. Read 22453 times.
Brown
Re: What are the best used speakers for around 13K?
« Reply #100 on: 28 Jun 2008, 02:04 pm »
What about Maggie 20.1s.
bpape
    • Sensible Sound Solutions
« Reply #101 on: 28 Jun 2008, 02:06 pm »
 :thumb:
chgolatin2
« Reply #102 on: 28 Jun 2008, 03:30 pm »
Their isnt the "BEST SPEAKERS for 13K" the best speaker is all subjective to public opinion, nobody could be the judge but your own ears.  Go out demo a few pairs bring them home audition them, test them, compare room acoustics, your needs etc and then you can make YOUR BEST opinion.
Some have all the money in the world to spend on audio gear some dont however a 50k thousand may sound good but a well built, well planned system for under 20 t0 10 may blow the 50k system away.  Is  not how much you spend but how well you balance your system out, how well you built it for your own needs and remember room acoustics are VERY VERY important~!
Good luck~!   :thumb:
toobluvr
« Reply #103 on: 28 Jun 2008, 03:41 pm »
Good luck~!   :thumb:
Succinct, to the point, and spot on!
When it comes to audio, truer words were never spoken.
 :thumb:
mcullinan
« Reply #104 on: 28 Jun 2008, 03:49 pm »
So true. So many opinions/choices, I just have to take my time and go listen to the post suggestions thats been made. Its going to take a while, but itll be a worthwhile search. It makes no sense in getting rid of anything, just to replace them and keep that cycle. I already have some nice speakers on the way (SP Techs), and I have Merlins now. Basically I bought the Merlins just from the many reviews without hearing them.
Someone asked on another thread, Well what do you feel is missing in your system.. Im not sure, though I am an around the corner kind of guy, lol.  Anyways.
Ill start there. Maybe hit RAMF someday if the wife allows it!  :D
There has to be 50 speakers in this thread. No narrowing there. Thanks so much!
Mike
SET Man
« Reply #105 on: 30 Jun 2008, 01:28 am »
Hey!
   Well, Mike/mcuallinan after you get your new $13K maybe you should do a Rave or Mini-Rave with your new speaker. :wink:
Take care,
Buddy :thumb:
topround
« Reply #106 on: 30 Jun 2008, 01:36 am »
mike,
how about some Sonus Faber Cremonas?
giantsteps
« Reply #107 on: 30 Jun 2008, 01:48 am »
mike,
  :scratch:
 Dr. Prat ...................have you forgotten the Vandy 5A's?
Frank
Wind Chaser
« Reply #108 on: 30 Jun 2008, 03:07 am »
Too bad you don't live in IL...
http://www.audiocircle.com/index.php?topic=57085.msg502211;topicseen#new
He don't need to live in IL.  Shipping to NY is possible.  Even with the cost of shipping, it's still a fantastic deal...
IronLion
« Reply #109 on: 30 Jun 2008, 03:11 am »
This is for P/U only, in Wilmette, Il.
I think he do need to live in IL.
Wind Chaser
« Reply #110 on: 30 Jun 2008, 03:22 am »
I think you wrong.   The seller says...
STEAL THESE for 10k delivered  including packing, palleting, shipping, and door to door service via craters, and freighter's., in the continental USA.  These would be well over 25k if ordered new.
LINK TO ABOVE QUOTE
Double Ugly
« Reply #111 on: 30 Jun 2008, 03:23 am »
It reflects a change of heart in a different thread, IL.
SAD, yes, but, I will get em again, in fact even better ones, also, checked out Craters & Freighters, I will ship if need be. :duh: :drool:
IronLion
« Reply #112 on: 30 Jun 2008, 03:26 am »
Thanks DU, didn't see that!  :lol:  I would buy them if I had the money...and space...Windchaser you should buy.  I think you like.
giantsteps
« Reply #113 on: 30 Jun 2008, 03:28 am »
 I be enlightened. :duh: :thumb:
 Frank
Wind Chaser
« Reply #114 on: 30 Jun 2008, 03:31 am »
I've got a very lousy room and a critical shortage of space.  The smallest mini monitors are the only practical solution for my present situation.
Wind Chaser
« Reply #115 on: 30 Jun 2008, 03:33 am »
 Frank
You just be Frank.  OP Mike need the light. :lol:
ecramer
« Reply #116 on: 30 Jun 2008, 03:36 am »
I'm sure Frank will store them for you, checking them daily to insure there safety.  :lol:
  • Speakers....What Speakers ?
« Reply #117 on: 30 Jun 2008, 03:37 am »
The Mini's would fit your room John.... :wink:
Wind Chaser
« Reply #118 on: 30 Jun 2008, 03:39 am »
You haven't seen my room. :(
« Reply #119 on: 30 Jun 2008, 03:43 am »
No one's room is as bad as mine....not even yours.
"Its a warehouse in here !! " :evil:
A quote from my better half.... :lol:  :?
