0 Members and 1 Guest are viewing this topic. Read 12181 times.
You don't have a single backup? If nothing else, burn your photos to CDs or DVDs. From the problems you're describing you could be on the verge of a catastrophic failure, and you should count your blessings each time the machine boots up normally after a lock up. You're living on borrowed time, I tell you! Get an external HD today!
Whether or not it works that seamlessly remains to be seen. I am not sure if you get a fully bootable disc or if it just performs incremental backups, which isn't anything new.
I hear ya Wind Chaser, but it just takes that ONE time when you lose something you care about, though.
WAIT! Hang on folks, do we even know for certain where and when Double Ugly's system is freezing? I'd like to know more information. It could be something very simple. Don't be too quick to throw in the towel (reinstall), you could end up making the problem worse. Especially if you're not familiar with the system. (no offense DU!)
When exactly is it freezing up during the boot process? If the main menu bar does not appear and you get the beachball then it could possibly be a bad font. If not, it could be a dozen different things. What applications are loading during boot for instance. Is just one app freezing or is everything frozen?
Catastrophic failure, eh? Wow, in all these years I've never backed up anything or had a HD fail. I don't believe in back ups or condoms for that matter. Just not the worrying kind.
DU, I really feel it for you. Although I have 2 Macs, I did not have the "luck" to upgrade to Leopard yet...run Panther in my old Mac Mini G4 and run Tiger in my 12" PowerBook G4. If I was in your shoes, I would attempt to go back to Tiger and escape from all these problems you have been having. If you had the original discs, I am sure you could do that. Afterwards, I would simply wait for Leopard to stabilize some more.
I highly suspect the newer OS is the main culprit in this entire ordeal. Of course, it is not as if I have never gotten spinning balls of death while I do something in Panther or Tiger, but it unusually happens only when I access a certain page in Firefox...which I think is badly coded and therefore causing the unknown crashes. It has not happened to me for a while do. Sometimes, it also happens to me when I think that the memory or the main processor has become fully overloaded...and if I do not do much and let time pass, the process takes place and the spinning ball is gone.
Then again, it hasn't happened since I nuked the fonts (just jinxed myself, huh).
DU, I'm horrified to hear of your continuing Leopard problems. Since the freezes seem to occur mainly during browsing, have you tried using Safari instead of Firefox as your primary browser? Safari was just upgraded with better HTML support. At least this might be a way to narrow down the problem.http://www.macrumors.com/2008/03/18/new-html-and-css-features-in-safari-3-1/
btw, I am excited to read about the newly updated "N" Airport Express ($ 99). Would this not be the perfect way to bridge/extend the range of a wifi network with an Airport Extreme/ Time Capsule base station for a wireless Squeeze network?
DU:Mac discussion forums are another place to get help. They are accessed from the Support link on the Apple home page.
Ok, I'm out of hiding. All of the advice given here is great. I was reluctant to mention this because I have a different issue, but the only program I've consistently had problems with since installing Leopard is.......................Firefox. I don't get the SBBOD like you do, though. I never turn my machines off and over time Firefox (which is always open, as is Mail) seems to go into a coma: menus drop down, links highlight, but clicking does nothing and the only way out is to Force Quit. I've done all of the suggestions mentioned here (nuking fonts, Disk Warrior etc), but to this day it still happens, usually every 4-5 days and I still have no idea why other than a compatibility issue with Leopard. I eagerly load each new update to Firefox, but I still have the same problem. You may want to try and use Safari for a week or two and see if the issue goes away. I have a gut feeling Firefox is your culprit here.Regarding backups, I use Apple's Backup utility for incremental backups to an array of off-net FW drives for music and photos which are all located on NAS drives, and Time Machine to a Time Capsule for for everything on the machines themselves. Carbon Copy is a great utility also and provides for bootable backups.
Hmmm…well, here's a few things to try: Bring up the Activity Monitor and see what processes are running. There may be one or two things that are eating up CPU power. If just certain sites are causing problems try loading them with different browsers. Check to see if Cookies are possibly blocked. Try deleting the misbehaving application's preference file. Check the Network setting, if you are using a proxy server those settings should also be put into the browser. Check for updates for both your apps and system-wide. Check your Login Items under Accounts to see if anything weird is loading during boot. Try creating a new user account and see if the same issues occur.
