0 Members and 1 Guest are viewing this topic. Read 12177 times.
Perhaps your network (cable modem) is freezing up, which may cause the programs to hang.
You may also have a font issue. Try this: http://www.macupdate.com/info.php/id/21536/fontnuke Im not so sure its a font issue, but.. I dont think it can hurt. Run permission repair also.
Permissions repair is found in the disk utility app in the Utilities folder. Open disk utility and run repair permissions there.
I know there are a few updates to airport if you are using wifi.
You may want to update leapord too.
Hey Double, do you ever try 'Force Quit' of the app when this happens? 'Opt' + 'Cmd' + 'esc' brings up a box to quit which ever app is giving you trouble.
... but where do I find required updates which aren't included in the "Software Update" function?
Same question... in addition to those I've already applied? If so, where do I find them?
In cases (rare) when I've seen the pinwheel, I've been able to move the cursor over the dock and work in other applications -- or in the Finder. Once over the dock, I am able to select Applications, then the subfolder Utilities, and open the "Activities Monitor." That tells me what application is hung and I can select it and force quit.
Yes, repair disc permissions in Disc Utility.As far as updates are concerned, Software Update takes care of all required updates depending on what OS version and applciations you are running. For a listing of all updates, you can check http://www.apple.com/support/downloads/.
The computer came with Tiger installed. I upgraded to Leopard myself and everything seemed to go well, but I've read where some have experienced issues until they performed a clean install
Very Nice system!
If you did the upgrade, you can also do a clean install! After booting from the Leopard disc, at some point (I don't remember exactly when) an 'Options' button is available. Clicking on it will you give you three installation options: An upgrade (default), Backup existing OS without deleting, and Clean Install (which will wipe your disc clean before installing). It's as simple as that. One thing to remember, though, is to have the other discs available that came with your machine as they are the means to reinstall certain preinstalled applications (iLife etc).
Agree that "archive and install" is a good thing to try. I know it's a bit inconvenient as you have preferences, passwords, and whatnot all set up. However, since you are having regular trouble, a clean install is desirable. Also -- sorry if you've already said this -- have you run a validate and repair with Disk Utility? You may have to boot off another disk to do this one.
A good disk utility is DiskWarrior, it can fix stuff the Apple disk utility can't. Highly recommended.
DU:Before reinstalling software you might try a program called Onyx if you haven't already. It can be downloaded free from Version Tracker or Cnet sites. After you run the initial screens try Automation. It will do lots of things. I've found it very helpful.
DU,Excuse me for asking, but WHAT ARE YOU THINKING? You don't have a single backup? If nothing else, burn your photos to CDs or DVDs. From the problems you're describing you could be on the verge of a catastrophic failure, and you should count your blessings each time the machine boots up normally after a lock up. You're living on borrowed time, I tell you! Get an external HD today!Whew, sorry about the rant but to give you an idea of where I'm coming from, I backup my backups.
