0 Members and 1 Guest are viewing this topic. Read 12171 times.
So far so good with Safari? No SSBOD?
I hope your computer is running a little better Double!
Try This--->A fix that has worked for various other Safari 3.1 issues has also proven successful for this problem: changing the user agent. To do this, you first need to enable the develop menu. Go to the "Safari" menu, then "Preferences," then "Advanced" and select "Show Develop menu in menu bar." The Develop menu will appear in the menubar. Select in, then navigate down to the "User Agent" section of this menu and note the various browsers available as user agents.Select 'Internet Explorer 7.0.That should fix your single line problem.
Urm... well, I put in an evil hack - the code now thinks that Safari is always Firefox... let me know if this causes other problems...This is, of course, something a responsible web programmer should never do.
Way to go DU!
The longest thread to-date in this young circle. Can't wait for your next problem.
So I assume all is well so far?
DU,Any updates?
The answer I received a few days ago was:"The fix I provided works with SB, TR and SBR, but needsto be verified by our QA team first and if they approve it,it is planned to include new firmware into the next bug fixrelease which would be 7.0.1.And to answer your next question, no, I have noinformation about when 7.0.1 will be released. Sorry."So, we just have to waitMvh
Just an FYI, Firefox released a new update a few days ago which I installed. So far, it seems to have fixed my non-response issue.
Do you think it's safe to give Firefox another try? I much prefer it, but I do not like forcibly shutting down the computer.
Download the latest Firefox update and give it a go. I'm curious.
Quote from: Crimson on 5 Apr 2008, 03:48 amDownload the latest Firefox update and give it a go. I'm curious.Another forced reboot, Crimson. I was perusing the Rivals site where the problem usually manifests itself, and sure 'nuff, the spinning pinwheel/ beach ball of death made an appearance.I'd visited several times since downloading the latest version, but I guess I didn't encounter the right script, combination of scripts or whatever triggers the problem. Back to Safari.
