0 Members and 1 Guest are viewing this topic. Read 47599 times.
Hi,I tried downloading slimcenter 7.0 via the zip file.I downloaded but that's as far as I got - I don't know how to install the new software.I had the option in winzip of open or extract or new or........aaarrrgggh!Whatever I did, I didn't know what I was doing.Are there a few easy steps someone with more computer knowledge could post to help me through the process of downloading and installing 7.0?Thanks!Bill
My RANDOM PLAY has disappeared. I just updated with the nightly and it is still gone................................... .........Anybody find it? All in all 7.0 has a lot of promise!
Quote from: mr_bill on 20 Nov 2007, 08:53 pmHi,I tried downloading slimcenter 7.0 via the zip file.I downloaded but that's as far as I got - I don't know how to install the new software.I had the option in winzip of open or extract or new or........aaarrrgggh!Whatever I did, I didn't know what I was doing.Are there a few easy steps someone with more computer knowledge could post to help me through the process of downloading and installing 7.0?Thanks!BillBill:I downloaded the Windows Excutable File in the list of choices here: http://www.slimdevices.com/downloads/nightly/latest/7.0/I downloaded it to the desktop, clicked onto the file and it worked like a charm.Good Luck:Ken
Quote from: Bigfish on 20 Nov 2007, 09:09 pmQuote from: mr_bill on 20 Nov 2007, 08:53 pmHi,I tried downloading slimcenter 7.0 via the zip file.I downloaded but that's as far as I got - I don't know how to install the new software.I had the option in winzip of open or extract or new or........aaarrrgggh!Whatever I did, I didn't know what I was doing.Are there a few easy steps someone with more computer knowledge could post to help me through the process of downloading and installing 7.0?Thanks!BillBill:I downloaded the Windows Excutable File in the list of choices here: http://www.slimdevices.com/downloads/nightly/latest/7.0/I downloaded it to the desktop, clicked onto the file and it worked like a charm.Good Luck:KenKen,I'm assuming the correct file for Windows XP is the Slimserver 7.0 a1 (Debian package). Before I mess something up - does it install on top of previous version and are all settings preserved?Thanks,Mike
Ken,That worked simple as can be.I love the new interface!Now if I could only get my weather information screensaver back on the SB3 I'd be really happy!I've tried, but can't get anything to work - help!Bill
Quote from: Turnandcough on 20 Nov 2007, 11:14 pmQuote from: Bigfish on 20 Nov 2007, 09:09 pmQuote from: mr_bill on 20 Nov 2007, 08:53 pmHi,I tried downloading slimcenter 7.0 via the zip file.I downloaded but that's as far as I got - I don't know how to install the new software.I had the option in winzip of open or extract or new or........aaarrrgggh!Whatever I did, I didn't know what I was doing.Are there a few easy steps someone with more computer knowledge could post to help me through the process of downloading and installing 7.0?Thanks!BillBill:I downloaded the Windows Excutable File in the list of choices here: http://www.slimdevices.com/downloads/nightly/latest/7.0/I downloaded it to the desktop, clicked onto the file and it worked like a charm.Good Luck:KenKen,I'm assuming the correct file for Windows XP is the Slimserver 7.0 a1 (Debian package). Before I mess something up - does it install on top of previous version and are all settings preserved?Thanks,MikeMike:I downloaded the third file down under Parent Directory (parent directory = 0). When you excecute the file from where you save it, it will remove the version of SlimServer you are currently running before it loads the 7.0 Files.Good Luck,Ken
Val, your comments about the sound improvement prodded me to install 7.0.....so, thank you! I'm assuming there will be a fix soon for the remote. Now if someone could explain why firmware changes can improve the sound. Nick
Well, I HAD the new squeezecenter running until I turned off my computer and now on restart the Squeezecenter will not start. The icon in the start up tray just keeps flashing and says 'Squeezecenter starting' but it never starts. If I double click on the desktop icon, nothing happens either - I get the hourglass to show for a split second and then nothing. I've tried restarting the computer a couple times, but nothing changes the 'Squeezecenter starting' and icon blinking in startup tray.Anyone know how to cure this, so I can get some music again!Bill
Just tried it, no go. Everything works fine when I go back to 6.5.
