0 Members and 1 Guest are viewing this topic. Read 47590 times.
We don't comment on future/unannounced hardware, ...
So if the remote is controlling the server side and not the hardware, is the extra box shown above part of the solution or does the SB simply pass a signal back to the server with no need for an additional network connection?
OK. So then the remote itself has to be able to connect to the network via a wireless connection if it isn't using the SB as a passthrough connection. It would be similar to the Nokia 700 just pointing a 'browser' back to the server - correct?
Quote from: bpape on 5 Dec 2007, 05:40 amOK. So then the remote itself has to be able to connect to the network via a wireless connection if it isn't using the SB as a passthrough connection. It would be similar to the Nokia 700 just pointing a 'browser' back to the server - correct?Right. The remote uses 802.11g WIFI to connect to the network, not IR. It's a two way communication stream, unlike IR. A lot of data, including every single pixel that gets painted on the remote's screen, moves over the wireless network. That probably has both its advantages and disadvantages.
Actually that's the way that the SB3 works now. Most of the commands are relayed to the server.
On the Jive if it was only IR, it wouldn't function as a multi-room controller. With the Jive's 802.11 you can control what's playing upstairs on the Squeezebox in the bedroom, or the Squeezebox in the kitchen, or the Squeezebox in the living room from anywhere in the house.
I had to uninstall Squeeze Center. That thing has way too many bugs. For instance, if I select my upstairs SB (instead of the downstairs SB), then choose a CD to play, the damn Squeeze Center would turn on the downstairs SB and play the CD on it. I simply could not control the upstairs SB using the Squeeze Center. I gave up and uninstalled.
Interesting. I wonder if I somehow modified some setting for this? I reinstalled 6.5.2 and it works the way I expect it to, which is that if I select the upstairs SB and select a CD, the upstairs SB begins to play the CD. With the Squeeze Center, the downstairs SB would begin to play the CD.
btw, wheres the power button and why don't slim remotes ever have a stop button?
The Jive Target Hardware Platform works with any of our products. It controls SlimServer not the hardware directly.We don't comment on future/unannounced hardware, but a SB4 sounds like you all think there is a SB3 replacement on the roadmap. There is not.To beat this dead... the SB3 will continue unchanged for the foreseeable future. There is no planned replacement for it.Cheers,MikeMichael ValeraOnline Communities ManagerLogitech Streaming Media Systemsslimdevices.com
Looks like squuezecenter beta has been updated with some bug fixes and firmware v84. Any one try it yet?
