0 Members and 1 Guest are viewing this topic. Read 47498 times.
Might try to use FW-83 in 6.5, has anyone done this.
Quote from: mr_bill on 22 Nov 2007, 06:26 pmWell, I HAD the new squeezecenter running until I turned off my computer and now on restart the Squeezecenter will not start. The icon in the start up tray just keeps flashing and says 'Squeezecenter starting' but it never starts. If I double click on the desktop icon, nothing happens either - I get the hourglass to show for a split second and then nothing. I've tried restarting the computer a couple times, but nothing changes the 'Squeezecenter starting' and icon blinking in startup tray.Anyone know how to cure this, so I can get some music again!BillSame problem here. Using Vista 32-bit
Quote from: PeteG on 22 Nov 2007, 06:34 pmQuote from: mr_bill on 22 Nov 2007, 06:26 pmWell, I HAD the new squeezecenter running until I turned off my computer and now on restart the Squeezecenter will not start. The icon in the start up tray just keeps flashing and says 'Squeezecenter starting' but it never starts. If I double click on the desktop icon, nothing happens either - I get the hourglass to show for a split second and then nothing. I've tried restarting the computer a couple times, but nothing changes the 'Squeezecenter starting' and icon blinking in startup tray.Anyone know how to cure this, so I can get some music again!BillSame problem here. I found my problem with help over on the beta forum and slimdevices.It was my Mcafee firewall that wsa blocking access. SImple thing, wish I would hae found it earlier!BillUsing Vista 32-bitI was having the same problems and found this: http://forums.slimdevices.com/showthread.php?t=40524. I upgraded my IE and things seem to be working great...lets hope that's all it is. I like squeezecenter alot!
Are you all sure that there is a difference in sound with the new firmware and SqueezeCenter ?I have been keeping up with the firmware/slimserver updates regularly.
You can't hear, men! I had the latest 6.5 nightly and there is a big difference with SlimCenter 7.0 and firmware 83. Big, bold bass and lower midrange that make the sound seem darker, more resolution, high midrange and low treble clear as a bell!
