0 Members and 1 Guest are viewing this topic. Read 47495 times.
Sounds like good news. By any chance, Tweaker, did you try to see if 15 will even work with SC7?
Quote Sounds like good news. By any chance, Tweaker, did you try to see if 15 will even work with SC7?I haven't. I can't really see any reason to as 15 was used to "fix" the sound and with 7.0 , to my ears anyway, there's nothing to fix.
Quote from: Tweaker on 11 Nov 2007, 04:21 amQuote Sounds like good news. By any chance, Tweaker, did you try to see if 15 will even work with SC7?I haven't. I can't really see any reason to as 15 was used to "fix" the sound and with 7.0 , to my ears anyway, there's nothing to fix. I'm another dinosaur still using FW15 Don't forget that the phase was inverted on FW15 but not on subsequent versions, so you will need to reverse the connections at the back of your speakers.
Quote from: DSK on 11 Nov 2007, 07:40 amQuote from: Tweaker on 11 Nov 2007, 04:21 amQuote Sounds like good news. By any chance, Tweaker, did you try to see if 15 will even work with SC7?I haven't. I can't really see any reason to as 15 was used to "fix" the sound and with 7.0 , to my ears anyway, there's nothing to fix. I'm another dinosaur still using FW15 Don't forget that the phase was inverted on FW15 but not on subsequent versions, so you will need to reverse the connections at the back of your speakers. Isn't that the other way around, that 15 doesn't invert phase?
HI, some more reporting on SlimCenter 7.I have installed version 7.0a on my Mac Mini (latest Intel version, 10.4.11) and have found that it plays my Apple lossless files fine to a stock SB2.Without critical listening, I have to say sound quality is fine.I have found another improvement from 6.5. So far I had been running 6.3 and ripping to apple lossless using Max. 6.5 refused to play those files for some reason so I went back to 6.3. SlimCenter 7 plays those files again.Slimcenter 7 is also nice and responsive but this may be attributable to the Mac Mini as well.
Hmm I use Max and SS 6.5.5?? w/e the latest version is and rip apple lossless and they play fine... My problem is I updated to 10.5 and everything works, except my Sirius plugin went kaputt. Anyone know anything of this.MIke
I installed SlimCenter 7 earlier today. While I'm not very familiar w/ the new interface, I do think that sound quality has improved noticeably. Harshness is reduced along with better detail acquisition and microdynamics.I preferred the music search capabilities of the old interface but I may need more time to feel comfortable with the new GUI.
