0 Members and 1 Guest are viewing this topic. Read 37519 times.
no, the eminence woofers are for sure in parallel - that's a classic OB bass thing. i don't which BMS compression driver is used in CS2, but whatever he uses it goes really low - deeply into a midrange territory. could be it's one of the BMS coaxial compression drivers which is actually mid and tweeter together.i'm a bit confused with behringer being mentioned - i've thought that emerald is EXCLUSIVELY using DBX products, at least known as an industry standard.LBNTL has anyone had a chance to check the "sock" that covers the baffle and drivers? i have 3 cats at home and if it looks like a big piece of clothed furniture they will start playing with it sooner or later. naked drivers are less of a problem.
Rather than speculate too much, the easiest thing would be to ask Clayton to walk it through. He was very accommodating so I'm sure it wouldn't be a problem. I was so wrapped up in the sound I didn't ask much about the science. That is indeed rare for me
Quote from: anubisgrau on 15 Oct 2007, 03:16 pmno, the eminence woofers are for sure in parallel - that's a classic OB bass thing. i don't which BMS compression driver is used in CS2, but whatever he uses it goes really low - deeply into a midrange territory. could be it's one of the BMS coaxial compression drivers which is actually mid and tweeter together.i'm a bit confused with behringer being mentioned - i've thought that emerald is EXCLUSIVELY using DBX products, at least known as an industry standard.LBNTL has anyone had a chance to check the "sock" that covers the baffle and drivers? i have 3 cats at home and if it looks like a big piece of clothed furniture they will start playing with it sooner or later. naked drivers are less of a problem.The crossover is listed as being 1kHz. The driver spacing between the tweeter and lower driver is 2-3 wavelengths at that frequency. This will cause significant comb filtering.Please note, i'm not arguing that the speakers don't sound great. I'm simply pointing out a potential design flaw; one that could be improved upon pretty easily, and emerald might consider trying out, if they haven't already. Of course, all designs involve trade-offs, and maybe this was a trade-off they decided to make in favor of efficiency.
Actually, that was something that I meant to check, but didn't... how did the CS2 sound off-axis? I spent all of my time in the sweet seat, as I had the room entirely to myself for most of the time I was there.
I'm somewhat sorry I asked. I didn't mean to knock down this thread's joy. I was asking in all seriousness. Comb filtering is a real phenomena and one that is readily audible and easy to predict so I was just stating the obvious in asking the question. Paul, I am not sure I understand your question.
How does the controlled directivity of a wave guide affect the comb filtering question?
