tanchiro58,Also questioned the others about whether this configuration changes the sound since I built the my first Felix based on the original schematic too...The first Felix I built used the Miller CMC and .47/.1/.01 caps; I built it exactly as the original schematic, placing the output .47uf cap next to the CMC, and the .01 bypass cap farthest away.I put this one in the AC line to my preamp and was very happy with the results.After seeing the other builds which placed the smallest value caps next to the CMC, I built another Felix this way using the same parts, and hooked this one up to my preamp.My results are subjective; but I seem to notice a little more detail and speed to the sound with the .01 bypass caps close to the CMC; at least in my audio system.I did not notice much difference with the different Felix config when they are used for my small TV monitor.Cheers.
JoshK's stunning good looks.... Cool
Coilcraft P3717-A CMC, available on Coilcraft's website--- I used X1 rated polypro caps from Digikey in values of 1uf, 0.1uf, and 0.01uf on each side of the CMC--- Part numbers are BC1576-ND, BC1587-ND, and BC1588-ND - Vishay/BC 440VAC X1 rated caps
Bottom mounting is an option for the 0.1uF. The thickness of the 0.01uF shouldn't be an issue. Adding a 15mm spacing to C3/4 is easy enough - I just made that change.The 1.0uF would be right on the input and output pads. Here's a quick image with an overlay of the MKP 338 1.0uF cap in the C1 position.Any reason X1's are being used? It seems like overkill.
FYI people, the X1 caps that Brad orginally used are rated for 275VAC, and the ones Gary used for his project (that I bought) are rated for 440VAC.
ok ppldont have to make it perfect, we need an operational decision and carry it outwe are all wating
I don't mean to be a jerk, but the reality is that even in the most ideal situation, final boards will take weeks to be in my hands. Here's the process:Finish design and order prototype boards.Order test-fit parts from at least three places (three different CMC's, multiple sizes of two different lines of caps)<wait a week to get everything>Test fit everything - if there are problems, go back to step 1 (each iteration is another $200)Start a group buy thread that allows sufficient time for people to get in orders and send payments (one week?)Order production boards<wait two weeks>receive boards, verify fit with test componentspackage and mail boards to everyone who ordered<everyone waits a few days to receive them>Even once a board is complete, these types of group-buys take several weeks. Naturally, all of this assumes I don't run into problems or have other time sinks come up.
Any consideration to space the line/neutral/gnd pads to accommodate readily available Eurostyle screw terminal blocks as an option?
