Felix project
0 Members and 1 Guest are viewing this topic. Read 267136 times.
Halvosh
Re: Felix project
« Reply #460 on: 25 Aug 2018, 10:49 am »
Hello ,
   Im also in the same boat .I would be very pleased if anyone has spares for the Felix i could buy from you .
  Thanks .Shaun
drmike
Re: Felix project
« Reply #461 on: 25 Aug 2018, 05:26 pm »
i've got some xtra boards.
drmike
BPT
  • Balanced Power Technologies
Re: Felix project
« Reply #462 on: 25 Jun 2021, 07:52 pm »
Anyone needing an inexpensive, well made chassis for a multiple Felix project please check out my ad in Trading Post-Accessories.
DIY AC Balanced Power Conditioner Parts Available (audiocircle.com)
BPT
feovo
Re: Felix project
« Reply #463 on: 11 May 2022, 11:29 pm »
hi
    is there any new changes in the design so far? thanks ,
feovo
Re: Felix project
« Reply #464 on: 11 May 2022, 11:30 pm »
is this correct
        0,1uF for digital sources, 0,22uF for analog sources and 0,56uF for amplifiers.
Speedskater
  • Kevin
Re: Felix project
« Reply #465 on: 12 May 2022, 01:07 pm »
Just some reminders on this old project:
a] all capacitors used in AC power circuits need to be 'X' & 'Y' types.
b] all power filters should be wired as close to their audio components as practicable.
