0 Members and 1 Guest are viewing this topic. Read 483834 times.
Does anyone know what did happen to Dan Mason?
I miss him. He was a very good friend and thoroughly interesting person. He made audio exciting.
Hi CK ~The thread that started it all... and where is the irrepressible and irreplaceable Dr. Dan Mason... he was very ill and moved back to Canada for some family care... I hope he is still with us. We miss you Dan and your sparkling beautifully voiced pros that had more texture and insights than any other writer on AC. You helped to open a new world of listening and gave many of us permission to build our own Open Baffle speakers... many many people jumped into the Open Baffle experience thanks to you, who would have otherwise simply taken the (expensive) commercial speaker route. And because of that we learned how to listen. We learned how to penetrate and see-through the hype of print or e-commercial magazines. CT, I am now using the Dayton Audio PS220-8 8" Point Source Full-Range Neo Drive speakers... phew!! what a long-winded name!!There is no comparison on my OB's... the B200's sound dull by comparison. They are cheaper and sound incredibly open, highly detailed and very musical.You can read a little bit about my experience with them on the second page of OB threads here on the Open Baffle forum... under the title:Replacing B200's with Dayton Audio PS220-8 8" Point Source Full-Range Neo DriveGood Luck... and thanks for bringing the Gravity Well Of A Dark Star back to life. It was fun to live there while Dan was still writing and the sparks were flying and our enthusiasm was racing with the moon.With Warmest Regards ~ Richard
One of the strengths of the B200 is its paper cone for musicalityThe Ps-220 has an aluminum cone?
Hi CK ~I am using the Eminence Alpha 15A bass driver that Erling once recommended. Although he now feels that there is a much better bass driver for a 2-way with using the B200 (or my Dayton Audio PS220-8 8") that if I remember correctly was designed for an infinite baffle so it probably has excellent bass retrieval, is tight and is fast. I have sent Erling a private email and hopefully he will get back to me soon (or he may see this thread) and we should know the driver he is recommending. I am also very very interested to try that driver... Erling has a way of being extraordinarily right about these things. There is no doubt, however, CK, that the Alpha 15A does the magic you are looking for. In my simple 2-way set up (one 8" wide-range driver, driven full-range and the 15" bass driver cut off with a gentle 6db slope using a simple coiled inductor at around 250Hz... I think) the sound is seamless... it is a perfect blending that I can not detect as coming from 2 different speakers... the Alpha and the Dayton blend perfectly to deliver an astoundingly coherent and convincing musical presentation... that will sound, if you have a well-designed amplifier (I highly recommend tubes... triode circuitry if you know what to get) incredibly alive, transparent, holographic, clear, with rich sonic textures and a highly saturated tonal palette. This is absolutely there if you are willing to have a little bit of patience and are willing to find the right auxiliary equipment that will help your drivers to sing to their full potential.I purchased it from parts express, they are selling it for $65: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-407&utm_source=google&utm_medium=cpc&utm_term=eminence%20alpha-15a&utm_campaign=G_MFG_DEF_Products_Exact&utm_group=290-407_Exact&9gtype=search&9gkw=eminence%20alpha-15a&9gad=6853578913.1cheapest price: $52: http://www.hotdealshop.com/html/productOverviewNew.aspx?prdId=23397FR071511 I experimented with wings before I finally settled on a simple flat baffle. I listened very carefully and found that wings when applied in any mass that could begin to reinforce the bass, smeared the tight clarity of the bass that is one of many amazing qualities of the Open Baffle paradigm. I was not happy about achieving more bass at the expense of clarity and a tight detailed presentation. Besides neither Deborah nor I feel the need for exaggerated bass... the type of music we listen to (every kind of voice, mostly small instrumental ensemble, or small orchestra) achieves its magic with tonal color and heightened sense of texture and a palpable sense of "presence". Many DIY designers on this forum use 2 bass drivers... and I can see that as a valid solution depending on room size and musical tastes. But I find that 1 15" bass driver is perfect for the musical gestalt that is convincing without being exaggerated.Your "problem" with the bass will be happily solved with the addition of 1 well-executed 15" bass driver (assuming your amp is not deficient in reproducing the bass)... you may want to make sure your baffle is resting on the floor to get the maximum of reinforcement from that coupling.Please keep in touch and let us know how things are working out... and let's see if Erling can remember the 15" driver that I think may be an even better match than the Alpha for your B200's. If they are not too expensive I think I will try them and report back to our community what I am hearing.With Warmest Regards ~ Richard
