Classic Stands - Bully
0 Members and 1 Guest are viewing this topic. Read 12722 times.
robwm
« on: 4 Mar 2025, 04:42 pm »
Hi,
I ordered a flatpack for the Bully speaker stands.
Does anyone have advice on finishing these?
Is it advisable to use spikes with the speaker stands?
I have seen some different foam, rubber, or damping materials you can glue on the top surface of the stands. Does anyone have experience with these products?
I also noticed in the GR-Research pictures that the stands might have veneer on them?
Thank you!
Rob
NIGHTFALL1970
Re: Classic Stands - Bully
« Reply #1 on: 4 Mar 2025, 05:55 pm »
Rob,
I purchased Herbies Audio Labs big fat dots with adhesive on one side. Attached them to the top of the stands. I put them at all four furthest corners. They work well!
« Reply #2 on: 4 Mar 2025, 06:00 pm »
For stands, I'd match the finish of the main speakers.
robwm
« Reply #3 on: 4 Mar 2025, 06:23 pm »
I don't think I have the money or motivation to treat my stands the same as the speakers. I chose some pretty spendy veneer and I know it will take a considerable amount of work to pull it off.
I like how the stands look when painted black. I'm not against that treatment. The GR-Research pictures look like they have some type of wood veneer. In that case, I might stain them.
The main ideas I'm trying to decide upon is the proper treatment of the top and bottom of the stands. The speakers will be wood veneer, so I don't want to scratch that when sitting on the stands. The flooring in our home is wood, so I don't want to scratch that either.
I'm not sure if I need to consider if the speakers could slide off the stands.
nlitworld
« Reply #4 on: 4 Mar 2025, 08:12 pm »
Simple basic black finishing is pretty easy with aerosol primers and trim black. Personal preference for something basic is Spraymax 3680405 black primer and 3680101 gloss trim black. (3680102 satin and 3680103 for matte). Second best option would be SEM aerosols of 42003 black primer and 49153 gloss trim black (49143 for satin or 49133 for matte).
These aren't fancy cans equal to what I'd recommend for long term on your speakers, but they'll work well enough and look clean on your bases without too much trouble.
As for protecting bases and speakers and floors, you could look at herbies dots, go the isoacoustic orea pods route, or even just some modeling clay to keep speaker from sliding on the bases. As for bases to floor, maybe some furniture dots for cheap or Gaia pods? You won't want double isolation devices used, but isolating at the floor or at the speaker is not a bad idea.
robwm
« Reply #5 on: 5 Mar 2025, 07:09 pm »
Ok, so this is what I came up with for an idea.
I will be rounding over the top and sides of my Bully speakers by 1/2". I will apply DuraTex to the front of the speaker and over rounded part. From there the rest of the speaker will be wood veneer.
So, for the stands, I'm thinking of using quality cabinet paint and DuraTex. The vertical boards will match the veneer color which should be a reddish orange. The tops and bottoms I'll coat with DuraTex. Using two tones this way to tie in the speakers would make it all look like a custom matching set.
I suppose this idea is subject to change. My mind is continually grinding on this stuff while I wait for the wood to be shipped.   :)
robwm
« Reply #6 on: 24 Mar 2025, 01:46 pm »
@NIGHTFALL1970,
Which size of Herbies Audio Labs Big Fat Dots will work with the Bully? Its footprint is 14" x 14".
Thank you!
Rob
NIGHTFALL1970
« Reply #7 on: 24 Mar 2025, 02:45 pm »
I think they were an inch. I ‘ll check when I get home. 8 of them were about $106.
robwm
« Reply #8 on: 24 Mar 2025, 03:29 pm »
I ended up buying the X-Large Dots. They are 1.5" in diameter and 1/4" thick for $130. Hobbs recommends the isolation for the speakers/stands.
crawdaddy
« Reply #9 on: 14 Apr 2025, 08:31 pm »
This is what I am using for stands to get the tweeters pointing at me.
corndog71
  • Some people call me Rob.
« Reply #10 on: 15 Apr 2025, 01:28 am »
Man, that looks good!
NIGHTFALL1970
« Reply #11 on: 15 Apr 2025, 05:13 pm »
Crawdaddy,
Those look amazing! I have never seen Bully’s in veneer before. I thought about it, but went with Duratex and glad I did. I have gouged them up a few times and putting a little Duratex on them you would never know. If I were to gouge up veneer, my eyes would always be drawn to it.
« Last Edit: 15 Apr 2025, 07:18 pm by NIGHTFALL1970 »
robwm
« Reply #12 on: 27 May 2025, 03:16 pm »
I cut up all the veneer for my Bully speakers and I have enough to veneer the tops of the stands. I don't have any other use for the veneer, and I don't want to waste it. So, my plan looks like this:
Wood veneer the top of the stands where the speakers sit. The sides and under side of the top piece will get duratex.
The vertical pieces will be painted with cabinet paint that matches the color of the speaker as close as I can get it.
The bottom piece will be covered with duratex on all sides.
I want to try to roll the duratex smooth for these stands. Has anyone tried rolling duratex smooth (untextured)?
Thank you,
Rob
robwm
« Reply #13 on: 3 Jun 2025, 04:14 pm »
One of the top pieces had a knot in it so I used some wood filler to fix that so it doesn't show through the veneer when it gets applied. All I need is some minor sanding of the top pieces and they are ready for veneer. I think I can get most of my veneer practice by working on this part of the stand first.
robwm
« Reply #14 on: 9 Jun 2025, 03:05 pm »
Well, I decided to change my plans a bit. I have a lot of Duratex on hand. I decided that I will paint the whole stand with Duratex except for the tops. I want to try to paint on the Duratex as smooth as I can get it. I have seen a few techniques to accomplish that.
I have enough veneer leftover from the speakers to veneer the top of the stands. I was able to glue one stand this weekend.
robwm
« Reply #15 on: 15 Jul 2025, 06:16 pm »
I have the veneer on both stands with 4 coats of oil-based polyurethane so far. This wood is not perfect, so I had to use U-Pol Dolphin glaze to repair the defects. I also used DAP wood filler to address all of the glue lines. I wasn't sure if the Duratex would hide them.
One stand has 3 coats of Duratex on the bottom. I discovered that Duratex doesn't cover Bondo Wood Filler very well. You can see the repairs through the paint. Because of this outcome, I will primer the rest of both stands before continuing with the Duratex.
The only real tip I have for this kit is to be sure that you can dry fit these stands with ease or you could end up with stands that are two different heights. It will take some sanding to be sure these go together smoothly. One of my stands is 1/8" taller than the other because I didn't follow my own advice. Danny says the height difference is a non-issue in my case.
I'll post some pictures in a day or two.
-Rob
robwm
« Reply #16 on: 17 Jul 2025, 07:07 pm »
This is where I'm at now. Since finding out that Duratex doesn't cover wood filler well, I decided to primer the stands before applying Duratex to play it safe. The top of the stands are veneered with Padauk and have 4 coats of oil-based polyurethane.
robwm
« Reply #17 on: 18 Jul 2025, 04:34 pm »
I have been applying thin coats of Duratex with a smooth foam roller on these. The left has 4 coats, and the right has 2 coats.
robwm
« Reply #18 on: 4 Aug 2025, 02:23 pm »
Almost done. I still need to touch up where the white primer is showing and then wax the tops.
Solarflares
  • Musical Guru and part-time Oxygen-Thief.
« Reply #19 on: 4 Aug 2025, 03:55 pm »
Great work
