Classic Stands - Bully
0 Members and 1 Guest are viewing this topic. Read 11837 times.
robwm
Re: Classic Stands - Bully
« Reply #20 on: 5 Aug 2025, 08:43 pm »
These are completed now. The only real advice I have is to ensure you can dry fit them easily (but tight fitting). Also measure the height of each stand while in the dry fit stage to ensure they are the same height. Lastly, this wood wasn't perfect. I had to use U-Pol Dolphin glaze to level the surfaces in some places. I'm not sure it would stain well either.
