Solid State or Tubes with your NX-series speakers?
Jaytor
Re: Solid State or Tubes with your NX-series speakers?
« Reply #160 on: 24 Apr 2024, 01:11 pm »
Earlier in the month I bought an Ayre KX-R Twenty preamp.  I am extremely happy with it.  I had the KX-5 Twenty prior to this, and a friend talked me into selling it to him.  It is also excellent.
That's a pretty cool looking unit. Bet it sounds great!
DanM88
« Reply #161 on: 25 Apr 2024, 03:23 pm »
Hey guys, I'm new here and just ordered an NX Studio to build. Does anyone have experience matching these speakers with an Anthem STR? Or should I look into tubes?
richidoo
« Reply #162 on: 25 Apr 2024, 06:23 pm »
Welcome to AudioCircle, Dan!
STR amp has plenty of power for NX Studio. It is relatively neutral, and should be a good match, imo.
DanM88
« Reply #163 on: 25 Apr 2024, 07:22 pm »
Thank you!  I'm excited to start the build and I can't wait to hear these speakers!
jmimac351
« Reply #164 on: 26 Apr 2024, 12:39 am »
« Last Edit: 5 Dec 2025, 07:08 pm by jmimac351 »
BrandonB
« Reply #165 on: 26 Apr 2024, 07:50 am »
I think it is better than the KX-5 Twenty, but the difference in price does not reflect the difference in performance - at all.  In fact, it was because the KX-5 Twenty was so good that I had confidence in getting the KX-R Twenty.  The differences are mostly due to higher cost parts. Apparently the resistors are much more expensive than the ones in the KX-5 Twenty.  And there is another important difference... the input switching is done the same way as the volume.  It's a more "direct" way of doing it compared to the KX-5 Twenty.  Ayre is very friendly / shares details about the design of the product.  Great guys.
You are getting that last 5%.
BrandonB
« Reply #166 on: 6 May 2024, 02:14 am »
I am leaning towards getting an Ayre QX-5 twenty DAC.  It has the volume control, so I don't have to get a preamp immediately.  I talked to Jake at Ayre and he said they are coming out with a streamer soon but he didn't know there would be a noticeable difference in sound  from the Ethernet card.  He actually mentioned that without me asking.  People in the forums really like the Ayre gear.
Jaytor
« Reply #167 on: 26 Sep 2024, 08:02 pm »
I am finally finished (at least for now) with my new preamp build. I started this project almost three years ago, and have built five different circuits for the tube line stage - the first two being John Broskie's Aikido designs, and the last three being my own designs.
This build is a fully balanced (differential) design. I'm using relay-based input selection and a balanced relay-switched stepped-attenuator. These are implemented using AMB.org delta 1 and 2 boards, but the control is done with an Arduino processor with my own software so I could use a TFT display and custom IR remote control. The code also controls power sequencing and an output trigger for my power amps.
The stepped attenuator is implemented with Vishay Z-foil series resistors and Audio Note silver tantalum shunt resistors.
There are actually two separate line stages - one is opamp based using AMB.org alpha 24 (A24) boards to drive my woofer towers, and the other is my own differential tube design. The A24 boards are powered by a Neurochrome Preamp power supply which provides a very low noise +/- supply.
The tube circuit is powered by independent custom Toroidy transformers for each channel, fed with a Neurochrome Smart Soft Start. The transformer outputs are filtered with a CRCRC circuit which then feeds a shunt regulator based on DIYAudio contributor Salas's SSHV2 circuit and implemented with my own custom PCBs. The shunt regulator voltage is 200V and is set up to supply ~28mA for the tube circuit.
The tube line stage that I finally settled on uses a pair of 6SN7 tubes, each with their sections paralleled, in a differential circuit. The cathodes are loaded with independent cascoded BJT current sources, with a resistor tying the cathodes together. This allows me to optimize the DC balance and reduce the gain a bit (to 13db) to better match the rest of my system. The anodes are loaded with a Lundahl LL1660 push-pull output transformer with a Nanocrystalline core in a 2.25+2.25:1 configuration. This circuit uses no global feedback.
Is that Attenuator in the second picture a really high end attenuator?  It is the same that is used in a preamp I'm looking at purchasing.
Brandon - I was reading through this thread and realized that I never answered your question from earlier this year - sorry. My previous preamp uses a Khozmo relay-switched attenuator. This is a nicely design circuit and I would consider it fairly high-end. It doesn't use the most exotic resistors in the signal path, but uses nice sounding ones. Much nicer than the typical Alps conductive plastic potentiometer used in many commercial preamps. I used an Audio Note silver tantalum as the final shunt resistor.
mkrawcz
« Reply #168 on: 26 Sep 2024, 08:09 pm »
Jaytor, that’s awesome! I’m about to work on my first real DIY preamp. The new Iron pre SMD balanced.
Jaytor
« Reply #169 on: 26 Sep 2024, 10:13 pm »
That should make a nice preamp. Good luck with it.
jmimac351
« Reply #170 on: 27 Sep 2024, 12:14 am »
morganc
« Reply #171 on: 27 Sep 2024, 02:11 am »
wow.  Stunning quality and build!  I sure wish I had those skills.  Beautiful work.
nlitworld
« Reply #172 on: 27 Sep 2024, 04:47 am »
Jay, that is phenomenal work. Did you DIY your own case as well or was the main enclosure something purchased? That almost looks like a PC case but not quite.
KTS
« Reply #173 on: 27 Sep 2024, 11:09 am »
Jay,
Your builds are amazing! I also wanted to complement your write up, every question I had was answered. Thank you for sharing.
Jaytor
« Reply #174 on: 27 Sep 2024, 03:18 pm »
Thanks guys. This project took a lot longer than expected but I learned a ton and had a lot of fun. It's given me a lot more confidence to do my own circuit designs.
I designed the case, but had the panels fabricated by Front Panel Express. I don't have the fabrication and finishing skills that you and others on this forum have, but I can use a CAD program and pay someone else to do it  :D.
mlundy57
« Reply #175 on: 27 Sep 2024, 06:00 pm »
This is seriously cool. Is it something you have built just for yourself or are you planning on building these for sale?
Mike
Jaytor
« Reply #176 on: 27 Sep 2024, 06:46 pm »
Mike
Thanks Mike. Just for myself. I'm happy to share design details (schematics, PCB layout, etc.) with anyone interested in building their own, but I have lots of other projects I want to move on to. I have yet another preamp I am half-way done with (even more sophisticated than this one), a streamer/DAC project that I just need to build the enclosure for, and a couple amp projects I've just started collecting parts for.
jmimac351
« Reply #177 on: 27 Sep 2024, 10:01 pm »
mkrawcz
« Reply #178 on: 27 Sep 2024, 10:08 pm »
Jay, out of curiosity, what wire did you use going to the XLRs? Looking for some good wire for my Iron pre.
jmimac351
« Reply #179 on: 27 Sep 2024, 10:27 pm »
