TeraDak DC-30 Linear Power Supply - Review
0 Members and 1 Guest are viewing this topic. Read 14465 times.
DarqueKnight
« on: 27 Feb 2019, 05:30 am »
Introduction
Very good results were achieved by replacing the stock generic "wall wart" power supply of my music library's hard disk drive enclosure with a lower noise iFi Audio iPower power supply ($49). Although the iPower power supply facilitates better sound than the stock power supply, it is still a switch mode power supply like the stock power supply. Accordingly, the quality of DC power supplied by it is affected by AC noise components. Linear power supplies are more suitable for audio applications due to their significantly lower output noise and isolation from AC line noise. The TeraDak DC-30 ($150) offers high build quality and high performance.
Background
This review is the fourth addendum to my review of the Bryston BDP-3 digital player. Music files for the player are contained in a 6 TB hard disk drive, which is contained in a Rosewill Armer RX304-APU3-35B external hard drive enclosure. This review will be more meaningful if the BDP-3 review, and first three addendums, are read first.
The original BDP-3 review is here:
https://www.audiocircle.com/index.php?topic=161770.0
The first addendum, a review of the iFi Audio iPower power supply used with BDP-3's  external hard drive enclosure is here:
https://www.audiocircle.com/index.php?topic=161895.0
The second addendum, a review of the iFi Audio Mercury3.0 USB 3.0 cable, used between the external hard drive enclosure and the BDP-3, is here:
https://www.audiocircle.com/index.php?topic=162115.0
The third addendum, a review of the Seagate 5 TB 2.5" hard disk drive, is here:
https://www.audiocircle.com/index.php?topic=162427.0
My listening evaluation methodology and the musical selections used are discussed in detail in the original BDP-3 review, therefore they will not be rehashed here.
At the end of the Seagate 5 TB hard drive review, I noted that I heard no difference between music files played from either the internal Seagate drive, or the external Western Digital Black 6 TB drive in its upgraded enclosure. However, when the external enclosure's upgrade USB 3 cable and upgrade power supply were taken away, music from the internal Seagate drive sounded better. The addition of the TeraDak linear power supply caused the external drive's sound performance to leapfrog over that of the internal drive.
Physical Overview
Figure 1. The DC-30 is encased in a high quality machined aluminum chassis. TeraDak recommends a break in period of one week. Clarity and detail improved after 24 hours. I did not hear further improvements due to additional playing time after that.
All those ventilation holes are not there for show. The DC-30 gets hot. Linear power supplies have lower efficiency than switch mode power supplies, therefore more of a LPS's energy is converted to heat. The top cover was 120 degrees Fahrenheit within a few minutes of being turned on. In comparison, the heat sinks of my Pass Labs X600.5 power amplifiers are in the range of 125 to 130 degrees Fahrenheit after an hour of playing at moderate levels (~85 dB-C). Temperature was measured with a Fluke model 561 infrared thermometer.
The DC-30 measures 4.25" wide by 6.5" long by 2.375" high and weighs 2.1 pounds.
Aluminum panel thicknesses are as follows:
Front panel: 0.12"
Rear panel: 0.08"
Side panels: 0.155"
Top and bottom panels: 0.1"
Panel thicknesses were measured with Mitutoyo model CD-6 CSX digital calipers.
Figure 2. DC-30 rear panel. Output is 12 volts at 2 amperes, same as the Rosewill enclosure's stock power supply.
Figure 3. The fuse compartment below the IEC power cord inlet has a spare fuse (the fuse closest to the rear).
Figure 4. The interior of the DC-30 is dominated by the Audiophonics R-core transformer. The transformer might be a custom design as I did not find this model (R20-DS3853) on the Audiophonics website. The DC-30 is marketed as an upgrade power supply for the Musical Fidelity V90 DAC.
R-core transformers offer some of the sonic advantages of toroidal transformers at a much lower cost.
Figure 5. A 1 meter DC power cable and 1.5 meter 18 gauge IEC power cord are included.
Figure 6. I didn't look closely enough at the picture of the DC-30's DC cable on the TeraDak website to notice it was a little bit too skinny. Standard size in the U.S. is an external barrel diameter of  5.5 mm and an interior diameter of 2.1 mm. The power plug of the cable I received was substantially smaller, as shown in figure 7.
Figure 7. The DC-30's DC power plug (bottom) was too small (3.46 mm barrel diameter) for the Rosewill enclosure's DC power port. I ordered two different color Switchcraft plugs #762 (black) and #763 (red) from Mouser. I couldn't decide which color I liked best prior to ordering.
TeraDak confirmed via email that a 5.5 mm x 2.1 mm plug is available, but it, like the input voltage, needs to be specified at the time of ordering.
The Sound
In summary, the spatial improvements were spectacular.
A playlist was made of twenty songs, ten pulled from the internal Seagate drive and the same ten pulled from the external Western Digital drive. Music from the external drive, with the TeraDak LPS, had the following differences:
1. More weight and more of a sense of space around sound images.
2. Increased tactile sensation: More sound pressure against my chest and upper arms corresponding to bass beats.
3. On some songs, some sound images were raised 6 inches to 1 foot higher.
4. On some songs, depth was increased by the sound stage moving forward up to1 (or more) foot in the center and up to 2 feet (or more) at the sides.
5. Piano notes had more detail, sustain, and decay, and more airiness and "sparkle" in the high notes.
6. More detail in bass micro-rumble and micro-growl.
7. Lowered noise floor as evidenced by the music sounding louder, but not actually measuring louder.
8. More dynamics.
9. Sharper transients.
Measurements
Time domain (sine wave) and frequency domain (Fast Fourier Transform) measurements were taken with a Tektronix TDS-2012 digital oscilloscope.
The TeraDak LPS was plugged into a PS Audio PowerBase noise gate/isolation platform, which was plugged into a PS Audio P10 AC regenerator, which was plugged into a dedicated 20 amp AC circuit terminated with an in-wall PS Audio Soloist SE passive power conditioner.
Figure 8. Sine wave plot of passively filtered open circuit AC voltage from the wall. The waveform shows flattened peaks due to harmonic distortion and other power line noise.
Figure 9. Sine wave plot of regenerated open circuit AC voltage measured at the output of the PS Audio PowerBase: A near perfect sine wave shape.
Figure 10. FFT plot of passively filtered open circuit AC voltage from the wall. The only signal of value is the large spike on the left, which represents the 60 Hz power signal. Everything else is harmonics, the power company's 470 Hz signaling tone, and noise.
Figure 11. FFT plot of regenerated open circuit AC voltage measured at the output of the PS Audio PowerBase: Drastic reduction in harmonics and noise.
Figure 12. FFT plot of open circuit AC voltage measured at the output of the Rosewill enclosure's stock Flypower switch mode power supply. This power supply generates even order harmonics, which were not present in the original voltage signals from neither the wall nor the AC regenerator.
Figure 13. FFT plot of open circuit AC voltage measured at the output of the iFi Audio iPower switch mode power supply. No even order harmonics were generated, but the odd order harmonics are significantly greater in amplitude in the voltage from both the wall and the AC regenerator.
Figure 14. FFT plot of open circuit AC voltage measured at the output of the TeraDak LPS. In stark contrast to the switch mode power supplies, no AC artifacts at all.
Tweaks
After preliminary listening evaluations were completed, attention was turned toward tweaking. The first thing to address was the DC-30's very bright LED.
Figure 15. Something needed to be done about that "red sun" LED.
Figure 16. Even with the audio equipment cabinet door closed, the red sun still shined brightly.
Figure 17. A double layer of blue film reduced the red sun to a warm, mellow red glow.
If you have had good results with audio grade fuses and audio grade power cords, and if you are interested in this, or another, linear power supply, an upgrade power cord and audio grade fuse is worth auditioning.
Figure 18. The stock 18 gauge power cord was replaced with a Signal Cable MagicPower 10 gauge power cord ($79) that was in my box of spare power cords.
Figure 19. After some audio grade fuse trials, the stock 5 mm x 20 mm Miro R054 1A, 250V slow blow fuse ($0.25), was replaced with one of the HiFi Tuning SilverStar 1A fuses ($40) I had on hand.
Off To Work
I took the Teradak LPS to audition in my system at work. The internal Seagate 5 TB hard disk drive had already been placed in a Rosewill Armer RX304-APU3-35B external enclosure in order to take advantage of the Rosewill's drive spin down feature. The iPower power supply formerly used in my two channel system had been transferred to the work system. The improvements were immediately obvious and similar to what I heard at home. A second TeraDak LPS was ordered for the work system.
https://www.audiocircle.com/index.php?topic=144829.0
Comparison To Network Attached Storage (NAS)
A NAS is used by some audio enthusiasts to host their music libraries. Ethernet is a low noise transmission protocol due to the fact that Ethernet ports are galvanically isolated (transformer coupled). Therefore, there is no direct electrical connection between devices on an Ethernet network. Accordingly, most of the electrical noise in a device does not get transmitted to other devices over an Ethernet cable. A small amount of noise does get transferred over, but it is usually negligible in amplitude and usually inaudible.
I transferred 7 DSD64 songs to the Synology DS918+ NAS in my home theater system. The seven songs' titles were edited to include the acronym "NAS" at the end. A share was set up on the BDP-3 digital player's NAS interface.  A playlist was made of the NAS songs and their counterparts on the external drive attached to the BDP-3. Songs from the NAS sounded identical in every way to songs from the external drive with its enclosure's upgraded power supply and upgraded USB 3 cable.
The first trials were done with songs streamed wirelessly via the following transmission chain:
Synology NAS ==>Ethernet Cable==>Wireless AC Range Extender #2 ==>Wireless Air Interface==>Wireless AC Range Extender #1==>Ethernet Cable==>BDP-3
With wireless streaming from the home theater NAS, I experienced occasional 1-2 second dropouts and stuttering. This was surprising, since wirelessly streaming 2K and 4K Blu-rays to any of my home's other televisions never experience any dropouts or stuttering. The home theater television has a wired connection to the NAS.
I ran a 50 foot Cat5e cable from the home theater's NAS to the two channel system's wireless AC range extender. Streaming of music from the NAS over the wired connection was flawless.
Wired transmission chain:
Synology NAS ==>50' Ethernet Cable==>Wireless AC Range Extender #1==>Ethernet Cable==>BDP-3.
Summary Of Results
The summary of results is as follows:
1. The internal 5 TB Seagate HDD sounded better than the 6 TB WD Black HDD in the stock Rosewill enclosure.
2. The 6 TB WD Black HDD with the Rosewill enclosure's iFi Audio iPower switch mode power supply and iFi Audio Mercury3.0 USB 3 cable sounded the same as the internal 5 TB Seagate HDD.
3. The 6 TB WD Black HDD with the Rosewill enclosure's TeraDak linear power supply and Mercury3.0 USB 3 cable sounded better than the internal 5 TB Seagate HDD.
4. The Synology NAS sounded the same as the 6 TB WD Black HDD with the Rosewill enclosure's TeraDak linear power supply and Mercury3.0 USB 3 cable.
5. The internal 5 TB Seagate HDD sounded better than the 5 TB Seagate HDD in the stock Rosewill enclosure.
6. The external 5 TB Seagate HDD in the Rosewill enclosure with upgraded USB 3 cable and upgraded power supply sounded better than the internal 5 TB Seagate HDD.
Further Study
The sound quality result with the Synology DS918+ NAS was intriguing. I am considering moving my music library to a Synology DS718+ NAS with two WD Red Pro 6 TB drives in RAID1 configuration. This option would cost $200 more than the current external hard drive connected to the BDP-3. However, the BDP-3 and its external hard drive are currently used as a quasi-NAS for the various computers and music players in my home. A real NAS would be a more efficient solution.
Associated Equipment - Home Two Channel Stereo System
PS Audio PowerBase isolation platforms for DAC, BDP-3, and U-Clock
22 pound granite slabs to couple source components to isolation platforms
Black Diamond Racing Isolation Mini Pits and Mk IV Cones
dCS Puccini U-Clock word clock
dCS Debussy DAC
Rosewill Armer RX304-APU3-35B hard drive enclosure with 6 TB WD Black hard drive
Pass Labs XP-30 line level preamplifier
Pass Labs X600.5 monoblock power amplifiers
AudioQuest Sky XLR interconnects
AudioQuest Everest speaker cables
Revelation Audio Labs Prophecy CryoSilver digital coaxial cable - RCA connectors
Revelation Audio Labs Prophecy CryoSilver digital coaxial cable - BNC connectors
Revelation Audio Labs Prophecy CryoSilver USB 2.0 dual leg cable
PS Audio PerfectWave AC-12 power cords
PS Audio PerfectWave P-10 AC regenerator
Polk Audio SDA SRS 1.2TL loudspeakers (heavily modified)
Salamander Synergy Triple 30 audio credenza
Logitech Harmony One remote
Dell 7140 tablet computer for system control
Associated Equipment - Work Two Channel Stereo System
Bryston BDP-2 digital player
Bryston BDA-3 digital to analog converter
Bryston BP-26/MPS-2 preamplifier/power supply
Bryston 4B3 power amplifier
Rosewill Armer RX304-APU3-35B hard drive enclosure with 5 TB Seagate hard drive
Polk Audio SDA CRS+ loudspeakers (heavily modified)
Douglass Connection DCF92 speaker cable
Revelation Audio Labs 1.25m USB 2.0 split configuration USB 2.0 cable
PS Audio Premier SC 1.5m Power Cords for amplifiers and source components
PS Audio PerfectWave AC-12 power cord 2m For P10
PS Audio xStream Transcendent XLR interconnects 1m
PS Audio xStream Transcendent XLR interconnect 1.5m
PS Audio P10 AC Regenerator
Revelation Audio Labs power umbilical for MPS-2/BP-26
maty
Re: TeraDak DC-30 Linear Power Supply - Review
« Reply #1 on: 27 Feb 2019, 10:03 am »
Thank you very much for the graphs!!!
I have added a link to your thread in:
< or = $700 Linear Power Supply Comparisons
https://www.audiocircle.com/index.php?topic=155847.0
DarqueKnight
« Reply #2 on: 27 Feb 2019, 06:37 pm »
Maty, thanks for referencing this thread in the LPS thread and for making me aware of the LPS thread. :D
brj
« Reply #3 on: 27 Feb 2019, 06:39 pm »
Another excellent review, DK!
Perhaps you mentioned it and I missed it, but... is the NAS plugged into the dedicated line and subsequent power conditioning chain?  (Based on the Ethernet cable lengths you mention, I was assuming not.)
Also, any chance you've measured the open circuit AC voltage on the output of the iFi and TeraDak when plugged straight into the wall, without your power conditioning in the mix?  I'd be curious to see just how much AC noise your extensive conditioning chain is preventing from getting through the different types of power supplies.
DarqueKnight
« Reply #4 on: 27 Feb 2019, 06:52 pm »
brj, those are very good points.
I neglected to describe the power delivery configuration of my home theater system. The NAS, source components, television, and networking gear are
connected to a PS Audio P5 AC regenerator which is on a dedicated 20 amp circuit.
The preamp/processor and three power amps are connected to a PS Audio P10 AC regenerator, which is on a second dedicated 20 amp circuit.
I did not measure the outputs of the iFi and TeraDak PSUs straight into the wall, but I will do so. Thanks for the suggestion.
DarqueKnight
« Reply #5 on: 1 Mar 2019, 11:41 am »
The following time domain (sine wave) and FFT plots are with the iFi Audio iPower power supply and TeraDak LPS plugged into a regular household receptacle and into the PS Audio AC regenerator power chain.
All measurements were taken within a few minutes of each other.
The regenerated AC power chain consists of the following:
Dedicated 20 Amp AC circuit==>PS Audio Soloist SE In-wall passive power conditioner==>PS Audio AC-12 noise filtering power cord==>PS Audio P10 AC regenerator==>PS Audio AC-12 noise filtering power cord==>PS Audio PowerBase isolation platform/noise gate.
Electrical Environment Graphs
Figure 20. Sine wave plot of open circuit AC voltage from regular household AC receptacle.
Figure 21. FFT plot of signal and noise spectrum of open circuit AC voltage from regular household AC receptacle.
Incoming power from the utility company has typical total harmonic distortion in the range of 1% to 1.5%, with the lower figure occurring in the early morning hours
(2am - 6am) and higher figure in the daytime and early evening hours. The total harmonic distortion figure of power from the AC regenerator is 0.1%.
Figure 22. Sine wave plot of regenerated open circuit AC voltage measured at the output of the PS Audio PowerBase.
Figure 23. FFT plot of regenerated open circuit AC voltage measured at the output of the PS Audio PowerBase.
Rosewill Enclosure Stock Flypower SMPS Graphs.
Figure 24. Time domain plot of open circuit AC voltage measured at the output of the stock Flypower SMPS plugged into the wall.
Figure 25. Time domain plot of open circuit AC voltage measured at the output of the stock Flypower SMPS plugged into the PS Audio PowerBase.
Figure 26. FFT plot of open circuit AC voltage measured at the output of the stock Flypower SMPS when plugged into the wall.
Figure 27. FFT plot of open circuit AC voltage measured at the output of the stock Flypower SMPS when plugged into the PS Audio PowerBase.
iFi Audio iPower SMPS Graphs
Figure 28. Time domain plot of open circuit AC voltage measured at the output of the iPower SMPS plugged into the wall.
Figure 29. Time domain plot of open circuit AC voltage measured at the output of the iPower SMPS plugged into the PS Audio PowerBase.
Figure 30. FFT plot of open circuit AC voltage measured at the output of the iPower SMPS when plugged into the wall.
Figure 31. FFT plot of open circuit AC voltage measured at the output of the iPower SMPS when plugged into the PS Audio PowerBase.
TeraDak LPS Graphs
These measurements were taken with the TeraDak's stock power cord and stock power line fuse.
Figure 32. FFT plot of open circuit AC voltage measured at the output of the TeraDak LPS when plugged into the wall.
Figure 33. FFT plot of open circuit AC voltage measured at the output of the TeraDak LPS when plugged into the PS Audio PowerBase.
The following measurements were taken after installing an upgrade power cord and upgrade power line fuse. The stock power cord
was replaced with a Signal Cable MagicPower cord. The stock power line fuse was replaced with a HiFi Tuning SilverStar fuse.
Figure 34. After power cord and power line fuse upgrades: FFT plot of open circuit AC voltage measured at the output of the TeraDak LPS when plugged into the wall.
Figure 35. After power cord and power line fuse upgrades: FFT plot of open circuit AC voltage measured at the output of the TeraDak LPS when plugged into the PS Audio PowerBase.
« Last Edit: 2 Mar 2019, 02:24 am by DarqueKnight »
maty
« Reply #6 on: 1 Mar 2019, 12:09 pm »
How much is the noise floor of the equipment used? Tektronix TDS-2012.
DarqueKnight
« Reply #7 on: 1 Mar 2019, 12:20 pm »
-27 dB (0.044 volts).
Figure 36. Background noise of oscilloscope with no input.
maty
« Reply #8 on: 1 Mar 2019, 04:07 pm »
In Europe, a very good idea to audio line dedicated is a differential superimmunized, aka SI. Like Schneider 25A A9R61225. Or Merlin Gerin. They incorporate a low pass filter.
https://www.schneider-electric.com/en/product/A9R61225/acti-9-iid---rccb---2p---25a---30ma---type-a-si/
[Big IMG] https://download.schneider-electric.com/files?p_Doc_Ref=PB104472&p_File_Type=rendition_1500_jpg
https://www.amazon.es/gp/search/ref=sr_qz_back?sf=qz%2Crba&rh=i%3Aaps%2Ck%3Adiferencial+superinmunizado%2Cp_89%3ASchneider+Electric&sort=review-rank&keywords=diferencial+superinmunizado&unfiltered=1&ie=UTF8&qid=1551456073
-> https://www.amazon.es/Schneider-Electric-A9R61225-Interruptor-Diferencial/dp/B00F8ORA7E/ref=sr_1_4?ie=UTF8&qid=1551456179&sr=8-4&keywords=diferencial+superinmunizado&refinements=p_89%3ASchneider+Electric  EUR 69,75
In USA, I do not know the rules.
I.Greyhound Fan
« Reply #9 on: 1 Mar 2019, 04:44 pm »
Can you adjust the voltage on the Teradak to use with a Regen?
maty
« Reply #10 on: 1 Mar 2019, 05:09 pm »
https://www.teradak.com/products/65.html
    Product Specification
        Output :  5V DC @ 3A
        Input power:  115V/230V AC
    Features
        High quality R-core transformer
        EMI filter for reducing AC power noise
        High quality power regulation with Panasonic FM capacitors
maty
« Reply #11 on: 1 Mar 2019, 05:17 pm »
Aleksandar (ATL Audio) has some LMPS, PCB or builded with different voltages. Original components and very good measurement. From Bulgary, EU.
You can build one or order him to do it according to your needs.
An example,
https://www.atlhifi.com/shop/populated-pcb/modified-sulzer-regulator-assembled-and-tested/
The regulator is offered with the following standard output voltages: 9V, 12V, 15V, 18V, 24V.
Sulzer 15V- 75mA OP37 graph
Bigger and builded,
Linear Power Supply Unit L-100
https://www.atlhifi.com/shop/fully-assembled-devices/linear-power-supply-unit-l-100/
– Input voltage: AC 115V or AC230V (according to the destination country or user request)
– Output voltage: DC 12V/19V/24V (user-defined values are also available upon request)
maty
DarqueKnight
« Reply #13 on: 1 Mar 2019, 07:05 pm »
The input and output voltage is set at the factory and is not adjustable by the user.
That is the DC-30 for the Squeezebox Touch.
My model is the DC-30 for the Musical Fidelity V90 DAC:
https://www.teradak.com/products/89.html
Power delivery instructions:
The main power supply panel default: silver silver shell
The input voltage of two kinds: AC100-240V
(the default 220V, but in other countries, according to the national use voltage is
the input voltage of 110V needs when photographed message notes or explanation with guest)
Power appearance specifications: 108mm (width) x153mm (long) x60mm (high)
Output voltage: DC 12V @ 2A
Krutsch
« Reply #14 on: 2 Mar 2019, 08:44 pm »
Summary Of Results
Further Study
 :popcorn:
I *did* try to explain that to you, in an earlier thread, using technical points (as opposed to listening tests).
Attaching an LPS w/ "audiophile" fuses to an external drive enclosure (or NAS appliance) is my personal definition of audiophile insanity.
DarqueKnight
« Reply #15 on: 2 Mar 2019, 09:47 pm »
:popcorn:
Thank you for sharing your personal insights regarding audiophile insanity. I will return the favor and share my insights regarding social
insanity.
My observation has been that people with anger management issues, deep personal insecurities, dire lack of interpersonal communication skills,
and general arrogance, typically become irritated, and sometimes angry, and begin hurling insults at people they see as challenging, or not following, their personal belief system.
This hobby is about the personal enjoyment of reproduced music. As such, there are no set rules that an audio hobbyist, audiophile, or casual listener must
adhere to when pursuing listening enjoyment or equipment evaluation. If someone chooses to listen and evaluate differently than you do, that is their right. It
is insane to expect that people must take your word for everything and then assume that they have some form of insanity if they exercise their evaluate things on their own.
While you are smugly contemplating your "technical superiority", I ask that you consider that you make yourself look foolish when you disparage listening tests in a hobby whose goal
is the listening enjoyment of high quality music reproduction.
Enjoy your popcorn.
brj
« Reply #16 on: 2 Mar 2019, 09:55 pm »
Very nice update, DK - thank you very much for making the effort!
Looks like the iPower benefits more from the power conditioning than the TeraDak.  In some cases the results are more obvious, and in others perhaps just 'different'.  The visible impact of only 1.0-1.5% harmonic distortion on the sine waves is interesting, though the downstream impact on any given component seems likely to depend on the quality of that component's own power supply design and execution.
Regardless, the TeraDak looks like a high quality, reasonably inexpensive LPS option!
And if nothing else, you're re-awakening my desire to pick up an o-scope! :)
(I have a dedicated subpanel and extensive power conditioning in my own system, starting with Environmental Potentials units in my mains panel through PI Audio devices of various types at the point of use, but I've never looked closely at the re-generator type devices.  May have to do some reading...)
ClefChef
« Reply #17 on: 2 Mar 2019, 10:06 pm »
This "review" is cringy to say the least.
"Linear power supplies have better power AC line isolation" - better than what? battery? smps? choke input unregulated? In some instances it could be quite contrary - 50 or 60 hz AC transformer could transfer power line harmonic noises, get saturated due to presence of parasitic DC. Then the silicone rectification and regulation adds its own noises to the supply.
Reviewer connected TeraDac to PS Audio SineWave generator - cheating.
Lots of extraordinary claims with no solid engineering or theoretical support. Audiophile fuses? Hard Drive listening test?
brj
« Reply #18 on: 2 Mar 2019, 10:24 pm »
He connected all tested power supplies both to the wall and to the PS Audio unit, so all units were on equal ground in all scenarios.  How is that cheating?
And he's attempting to correlate what he's hearing to what he's measuring using appropriate gear and infinitely more rigor of method than found even in most industry publications.  (Those that even bother to measure.)  How is that anything but helpful?
Even if people aren't interested in the devices that he's testing and reviewing, I'd encourage any comments to be constructive in nature, rather than merely dismissive, as comments of that type help no one.
« Last Edit: 3 Mar 2019, 02:30 am by brj »
DarqueKnight
« Reply #19 on: 2 Mar 2019, 10:37 pm »
One of the benefits of living in a "free" society is the right to express one's opinions and experiences without fear of being jailed or executed.
People are then free to accept, reject, or rebutt what has been stated. I am always appreciative of technical rebuttals and/or corrections that correct errors in
thinking or misunderstandings. However, your goal here seems to be to ridicule rather than to assist in understanding. That gives some insight into your character.
One of the basic tenets engineering of test procedure is that a thing should be tested according to the conditions in which the thing will be used.
The TeraDak LPS, like all of my audio and video gear, was going to be used with an AC regenerator, therefore that is how I evaluated it.
Better than the two particular iPower and Flypower switch mode power supplies it was compared to in this thread.
Furthermore, you misquoted me. My exact statement was:
Quote from: DarqeKnight
"Linear power supplies are more suitable for audio applications due to their significantly lower output noise and isolation from AC line noise."
