0 Members and 1 Guest are viewing this topic. Read 73169 times.
Hi KenThanks, that helped. Actually I needed to add a washer either side of the tray as well (this also helped to locate the screw head as the holes in the tray are a bit large)The suspension still seems a bit 'stiff' ( but doesn't foul the tray anymore)I've taken care to centre the spring 'cups' and that nothing is obviously rubbing. Can anyone confirm how 'free' the suspension should feel. I'm used to a sprung TurnTable but I guess the CD will not be this compliant.RegardsWestiebj
The modified “L” brackets will be located on the front facing side of the VFD board.
I also included two OPA627 to swap with OPA134.
Quote from: ken_diyzone.netI also included two OPA627 to swap with OPA134. What is a preferred source for the OPA627? What is the correct full identification (some have suffix letters as OPA627##: AM AP AU BM BP SM) for the OpAmp?DigiKey shows about 18$ ea. for the OPA627 Is this normal cost?Are these a drop in for the OPA134?, because the data sheet for the two shows the pins for NoConnection and OffsetTrim (#'s 8 & 5) are reversed for the two devices. Is rewiring of circuit traces needed here?Thanks.
