0 Members and 1 Guest are viewing this topic. Read 73526 times.
Julien: Is there any particular reason you chose the LT1085CT? There seem to be a fair number of the variants of the 1083 among which to choose. I use balanced power and haven't experienced any grounding issues. Sounds better, too.Regards,Larry Welsh
Hi Josh,They are for the Blue LEDs. Take power from the 5V board, and use 1K for resistor value, reduce by 20% if you think the LED is too bright, and vise versa.They fit on the inner tray that I mailed out to you yesterday.........Regards,Ken
Hi allSorry if this is a bit of a dumb question but I'm not too good with this. What power rating should be used for the resistors ? Is .125W OK ? I'm planning to use 20mA diodes. ( Luminous intensity, typ:1200mcd , viewing:30° )Also, I agree blue looks very nice, but would say green be more suitable. I ask because I remember years ago people using green marker pens on CD's supposedly to help reading the disk ( something to do with the wavelength of the laser ? )Thanks for any helpRegards
