$75.00 Sharp SD-EX111 : SOLD OUT
0 Members and 1 Guest are viewing this topic. Read 49158 times.
TIC
« Reply #160 on: 5 Mar 2005, 11:01 pm »
There is a "buy it now" dealer on eBay that has the Sharp for $77. Unfortunately, they charge $19 for shipping. This is still a good deal for someone that wants/needs a unit like this.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3279&item=5735764480&rd=1&ssPageName=WD1V
Heck, if these go the same way as the Sonic Impact amps, you'll be able to sell these on AudiogoN for $150 when the supply dries up.
I sold a Sonic Impact for $60 last week. The first responder bought it less than 5 minutes after I posted the ad on AudiogoN!!!!
Enjoy,
TIC
F-100
« Reply #161 on: 6 Mar 2005, 01:35 am »
Quote from: eric the red
Check out this review on the Overstock website :
Reviewer: Christine from Boston
"This unit does not have speakers, despite having speaker terminals listed. You will not be able to listen to this unless you have another set of speakers, or purchase a set. I am very disappointed that Overstock does not make this obvious and then charges a 15 restocking fee when their customer service agent also indicated that speakers were part of the stereo system. Why buy a stereo that doesn't come with speakers?"
I guess she was expecting a Boom box  :rotflmao:  :rotflmao:
suits_me
« Reply #162 on: 6 Mar 2005, 03:22 am »
You know, I agree with Christine. I've thought for years those people who buy expensive headphones and head amps are really, well, odd.
So I didn't buy a second Sharp in time...now I have to shell out for that Classik I've had my eye on. For my second system?  : >
KKM
« Reply #163 on: 6 Mar 2005, 04:57 am »
They still sell the SD-EX101, which appears to be the same unit but with speakers for $120.
http://www.overstock.com/cgi-bin/d2.cgi?PAGE=PROFRAME&PROD_ID=1082649
KT
« Reply #164 on: 6 Mar 2005, 05:28 am »
KKM,
I looked at the SD-EX101 and initially thought they were the same amp, too. They are, in fact, different. The EX101 samples at 2.8MHz whereas the EX111 samples at 5.6MHz. I don't know what effect this has on sound quality, but I would think the EX111 should sound better with the higher sampling rate.
Who knows, though? If anyone tries both, please let us know.
KT
JackStraw
« Reply #165 on: 6 Mar 2005, 03:30 pm »
Quote from: viggen
Tim, My Sharp sounded much better after 2 weeks.  Even the CD player improved to the point that I no longer use another CD player plugged into the AUX input.  Good luck with your "two channel".  :lol:
Did the Sharp CD player improve while you were using your other CDP through the AUX inputs? I'm planning to mainly use the Sharp with AUX inputs from my DAC, but I'd like to know if I need to burn the CDP in by playing it or whether the unit just needs to be running.
Vinnie R.
    • http://www.vinnierossi.com
« Reply #166 on: 6 Mar 2005, 03:38 pm »
Quote from: JackStraw
Quote from: viggen
Hi Jack,
If you want to burn-in the CD player section, you need to have a CD running.  (you can do this overnight if you leave the unit on repeat mode).If you are using the AUX inputs, you'll be burning in only the preamp section and the power amp section.
Also, I believe if you have the unit switched to AUX input, the CD motor will be disabled, so you can do both at the same time...
If you want to burn in everything, I'd connect a 4 ohm resistor across each output (5 watts will do as long as you don't have the volume cranked way up) and let it run on CD repeat mode overnight.  This is what I do to speed up the burn in process  :P
speaker
Re: $75.00 Sharp SD-EX111 mini system bargain alert: SOLD OU
« Reply #167 on: 7 Mar 2005, 01:05 pm »
Seems as if we are close to selling out-thanks for shopping at Overstock!
I bit the hook & bought one last night. I am anxious to get if hooked up & listened to.
speaker
ZooDog
« Reply #168 on: 7 Mar 2005, 05:22 pm »
I picked up some Dynaudio Confidence C1's for the Sharp.  What do you guys think?  It's not too much speaker, is it?
J@ck
« Reply #169 on: 7 Mar 2005, 05:28 pm »
Quote from: ZooDog
please let me know your experience with the C1 and the sharp. If the sharp can drive C1 well, it can handle most speaker in the market.
Thank you.
ZooDog
« Reply #170 on: 7 Mar 2005, 05:29 pm »
Goddamit, I can never get embedded images to work.  What am I doing wrong?
doug s.
  • makin' music
« Reply #171 on: 7 Mar 2005, 05:41 pm »
Quote from: ZooDog
zoo - yer second "[/img]" was on the line below the link; ya need to delete the space in front of it, so it gets on the same line as the link; then it will work.  if you "preview" the post before ya submit it, you will see wazzup...
hth,
doug s.
ZooDog
« Reply #172 on: 7 Mar 2005, 06:11 pm »
I fixed it.  Thanks Doug.
dave_c
« Reply #173 on: 7 Mar 2005, 06:38 pm »
That is sick!  At first it seems like overkill for a computer system, but damn I'm jealous!  What sound card are you using for your Mac?  How do they sound in that super nearfield configuration?
viggen
« Reply #174 on: 7 Mar 2005, 09:27 pm »
Quote from: viggen
Hi,
In my personal experience, I left the unit on 24/7 for about 2 or 3 weeks while listening to it about 2-3 hrs a day using either the tuner or the aux in.  On a whim, I tried the built in cd player and found it to sound not bad.  (I got lazy using the cd sleeve thingy on the NEC cdrom, so I just inserted the cd in the easy to use Sharp's cd slot instead).  The difference between my other cd set up and the sharp's cd player is very minimal now, so that I started using the Sharp's exclusively and am keeping the phonopre plugged into the aux.  Less fiddling for me.  :D .
ZooDog
« Reply #175 on: 7 Mar 2005, 09:35 pm »
Ok, I confess, I didn't actually buy $6000 monitors to match up with a $75 digital receiver.  The C1's are actually for my rig at home but when they arrived at work this morning I just couldn't resist hooking them up to the Sharp.  Sounds damn good though!
I am listening to the latest Sarah McLachlan (AAC file at 320/kbps) and her voice sounds wonderfully pure and smooth.  Kick drum is solid, though I am thinking that the C1's will play deeper with more power.  Highs are detailed and non-fatiguing, but seem a little unextended (I expect this is because of the AAC encoding).  First and foremost, they posess that natural tonality that have come to expect from Dynaudio speakers.
They sound fine in this near-field set up.  Imaging is rock solid and the drivers sound integrated.  I can't wait to get them home.
speaker
« Reply #176 on: 7 Mar 2005, 09:59 pm »
Quote from: ZooDog
I am thinking that the C1's will play deeper with more power.  Highs are detailed and non-fatiguing, but ...
Wouldn't they just play louder with more power?
speaker
tyee
« Reply #177 on: 8 Mar 2005, 12:10 am »
How is everyone receiving their unit. Mine came in a box with bubble wrap but no Sharp packaging internally, just some ends of stiff cardboard supporting the unit.
tyee
dave_c
« Reply #178 on: 8 Mar 2005, 12:40 am »
Quote from: ZooDog
I am listening to the latest Sarah McLachlan (AAC file at 320/kbps) and her voice sounds wonderfully pure and smooth.  Kick drum is solid, though I am thinking that the C1's will play deeper with more power.  Highs are detailed and non-fatiguing, but ...
Oh well, its a great pic anyway!   :lol:
Seriously though, if you think it sounded good on the C1's then that's a good sign.  Vinnie did mention something about the Low end being limited on the stock 111 so that might have something to do with the low end response.  But I'm guessing that the power does too.  I think Dynaudio's love power.  I heard the Special 25 powered by the Tri-Vista 300 integrated and it sounded like there was sub in the room.
ZooDog
« Reply #179 on: 8 Mar 2005, 12:43 am »
Dave,
I actually presently own the Special 25's.  I found a good deal on a pair of used C1's so I decided to pull the trigger and have a little Dynaudio showdown.  I'll post a review at some point.
