0 Members and 1 Guest are viewing this topic. Read 5843 times.
No reason a top mounted port could not work. In some cases it may even ease placement concerns as it will not load a surface nearby (such as a rear mounted port facing a wall).Lots of designs out there with downward facing ports in the bottom of an enclosure.
Regarding downward facing ports how much room have you seen between the bottom of the cabinet and the floor to allow for the port to breath properly? Would a good 1/2" or so suffice for small set of bookshelf speakers or would 1-2" be needed?
This is consistent with my own understanding but always good to hear from others. Regarding downward facing ports how much room have you seen between the bottom of the cabinet and the floor to allow for the port to breath properly? Would a good 1/2" or so suffice for small set of bookshelf speakers or would 1-2" be needed?
??? Am I missing something or didn't the op ask about putting the port in the top off the cabinet? Separate from the excellent discussion about downward facing ports of course. Perhaps the op could clarify or some of you guys could read over the op and point out what I'm missing?
I was responding to a specific follow-up question by the OP, quoted in my post.
Dust trap?
That's a downside for sure. Owner says he can live with that.
I'm thinking cup holder.
