0 Members and 1 Guest are viewing this topic. Read 544737 times.
Yeah, usually when one adds extra adapters / connections in a system, it affects the resolution in a bad way.For giggles and kicks, I had tried going single ended from my preamp, into a high quality Jensen Isomax converting tranny, to the Crown's balanced connections, but found just going from the pre's xlrs (with the converting op amps inside doing the work) sounded better. Probably because of less connections and cables involved.Also have to say, Magnepans can be pretty finicky with different amp setups. The other pro amps I have (Mackies and Yamahas), didn't sound that good on my MMGs. The Mackies, which were the worst sounding on the Maggies, do just fine in the HT system driving Paradigm Studios.That said, comparing this $350 amp to high end audiophile amps is interesting reading, but really does the audio cheapskate little good. You know, the guys who have to buy this amp cause of their budget. I would love to see more comparisons with amps like Class D Audio and Emotiva, and other amps in close to the same or slightly more price range.
I would like to see more "apples to apples" comparisons. There seems to be general agreement that the Crown XLS series is a budget amplifier winner. I am very curious how other Pro amplifiers in the same price range perform. The Behringer iNuke DSP series sell for about half the price of the Crowns, have the same basic Class D design and include DSP which would be a great feature in equalizing speakers and room deviations, which would make a much, much greater SQ improvement than binding posts and power cords. I am very tempted to buy the Behringer but currently I am up to my earlobes with amplifiers.
Gents, I'm thinking of getting a tube preamp and running my Dual Core on an input similar to what Tomy2Tone is doing.Would this preamp be a good choice for the Crown XLS amplifier as far as impedance matching and output?http://www.transcendentsound.com/Transcendent/Masterpiece.htmlChris
I would try one before I bought it, most pro amps do not sound this good. I tried out a Peavey amp a couple or three years ago, modified by TRL, but the TBI sounded better. I have a strong feeling the Drivecore chip is the strength of these Crown amps. Go on searchtempest.com to find a used 1500 for 150-200 bucks.
Thanks Steve and Zapper for some great feedback!
