0 Members and 2 Guests are viewing this topic. Read 554433 times.
Since I am going to have three 1500's, I will keep one stock, one will be cryo'ed, then one modded by Salis Audio and then cryo'd. I will see which one is the best and by how much. It might just be worth keeping these Crowns stock. I need to send my well broken-in one to the cryoman, he said if the unit is not broken-in, it could take up to 500 hours to burn in.
I have a question about break in time . I have two XLS1500 but have only been used in LowPass Mode for subwoofers and let me tell you they ROCK.Does the time used in lowpass hours do anything if I switch to Stereo Mode (Full Range)? Thanks Ken
Yes I do own Ncores and used the XLS1500 for 2 subwoofers . Earlier this evening I did hook up the Crown in full range and was kind of impressed but need to do some more comparing of the two. ZAK
I just know what works the best at my house with the dirty AC.
Zak,I look forward to your comments. If the Crown comes up short, get ready to explain:- why you chose not to cryo treat the Crown...even though there is no proof this is safe or improves the performance in any way. - why you didn't have thousands of hours break in on the Crown. If it doesn't sound good, no matter how many hours you have used it, the reason it came up short is because it needs a couple hundred more hours to fully break in. - why you didn't use those magic wood pucks (and cushy pads underneath for bonus points). The Crown cognoscenti can't live without their magic pucks and I can imagine people attributing the outcome of your evaluation to the use of these pucks, or lack thereof.
I am sure Tomy2's goal of this amp tour is not to see how it stacks up to the Ncores, he is being generous to see how you like these Crown amps.
