0 Members and 1 Guest are viewing this topic. Read 553196 times.
I'm moving here next week and will need an amp to drive my second system. Totally getting one of these.
Only tweak left to do on my two 1500s is to upgrade the power cords. Will need 1.5 m long each. Can anyone recommend a diy or premade cord, preferably in the $50-$75 range?
Would that be your Magnestands?
Thanks, got an Audio Advisor sale flyer just yesterday with Pangea on sale. Will check it out. Roscoeiii did you try the Shunyata on the loaner Crown when you had it?
So did anyone try the 193l/M Hammond choke tweak yet? I thought some folks were going to give it a go.
Arrrgghhhh! Received tour amp today, but discovered I have no easy way to hook it up. Speakers are biwired and cables terminated in spades, which the Crown doesn't accept. Never thought about that. Is there such a thing as a spade to banana adaptor? I suppose I could make some cheapie cables and jumper but was really hoping to hear this with system mostly as is.
Rob, don't feel bad about the imbalance debugging. It took me way too long to figure out an imbalance in my system wasn't a component but one of the RCA cables. This was after swapping out everything but the cable in question.Same thing happened with an odd sounding (but expensive) power cord. It stayed while all sorts of components got swapped in and out. When a good sounding DIY cord got swapped in as a replacement things just opened up. Up to that point I'd have never guessed it was a power cord.This can be a very strange hobby at times.
