0 Members and 1 Guest are viewing this topic. Read 20335 times.
Mike, I'm pretty sure that if he added 2-30A and a 20a that he did it on opposite branch legs of the panel to balance the load on the incoming service. Doing so will induce a ground hum when you connect all of this through your pre/processor because it will then see the different ground potentials from both branches of the service.Bummer.In order to minimize all of this, a separate subpanel containing all of the dedicated lines should be run so that grounding potentials are all the same.Make sense?Dave
As soon as my pre/pro gets any type of signal be it from my CD player, cable box, etc the hum starts.
I wanted to try that also but I'm not sure how to plug those 30 amp plugs into a power strip maybe some type of converter? However even with the 30 amp breakers shutoff the hum is still there it's still there of the 20 amp outlet is shutoff also, and I hook everything up the way it was before we add the lines.Dave the first thing I tried was uplugging the cable for the cable tv as I had that problem in my previous house and that's not the issue. I think what up you had mentioned before may be the problem. We are going to try adding another sub panel and a couple more dedicated 20 amp lines (surrounds are active) and see if that fixes it. I ready have 1 sub panel as is will that be okay to add a second?
Pre/pro broke? Replace it with a loaner.Wayne
I have been thinking the same thing. Need to find a loaner I suppose.
The easiest thing to do with all of these ground problems is to gut the system to a minimum system. Unplug everything from the amplifier and only connect the amplifier to the power (and to the speakers). Turn on the amp. Do you have hum? If not turn off the amp, add the preamp into the system (with nothing connected to the preamp). Turn on the preamp and amp. Do you have hum? If not, keep adding one device until you find the source of the hum.Using this, I determine a hum I had was caused by interconnects. It took me a while to realize this.
The easiest thing to do with all of these ground problems is to gut the system to a minimum system. TUsing this, I determine a hum I had was caused by interconnects. It took me a while to realize this.
