0 Members and 1 Guest are viewing this topic. Read 20334 times.
Correct. My TT's aluminium chassis is connected to mains earth. So is the (separate) aluminium plate which the motor is bolted to. But the 4 signal wires from the cartridge don't touch either of these pieces of metal. Regards,Andy
The turntable's signal has to reference the ground, somewhere, be it through AC power, signal, whatever. The path can become too long and disrupted. (I just fixed this on my own system)
Mmmm, let me try and explain, SA (sorry, the setup is so obvious to me, I can't understand anyone not 'getting it'? ).1. The turntable has no signal ... the cartridge does.2. The cartridge has no connection to ground - it simply has 4 wire connections going to the phono stage: - L & R channels - the 'signal' wire and the 'ground' wire on each channel.3. The 'ground' wires in the phono cable pass the 'signal ground' to the phono stage circuit.4. The phono stage signal ground has no connection with the phono stage case - which is connected to mains earth.5. The phono stage signal ground is then connected to the preamp signal ground, via the interconnect which joins them.6. Again, the preamp signal ground has no connection to the preamp case - which is connected to mains earth.7. The preamp signal ground is then connected to the power amp signal ground, via the interconnect which joins them.8. The power amp signal ground has no connection with the power amp case - which is connected to mains earth.9. Again, the power amp signal ground (and PS ground) has no connection to the power amp case - which is connected to mains earth.10. The power amp speaker terminals are then connected to the speakers.Simples! Regards,Andy
Yes because I believe you said all of your audio equipment AC power wiring is doubled insulated and equipment chassis does not need/use the safety equipment grounding conductor.I do find it odd you did not mention if the tone arm on your TT has a ground wire that connects to the phono preamp grounding post. Jim
mcallister,I have tried to follow your thread and have a few questions.How many 15 or 20 amp 120V branch circuits are used to feed the audio system? (Not counting the two 30 amp 120V branch circuits for the subs.)If I understand correctly each active danley speaker has it's own power amp and thus each is powered by a 120V cord and plug. Is that correct.All plugged into and fed from one branch circuit? Or fed from several?Here are just a few Links for you to read.http://www.aes.org/sections/pnw/pnwrecaps/2005/whitlock/whitlock_pnw05.pdfhttp://www.exactpower.com/elite/assets/pdfs/theTRUTH.pdfhttp://www.epanorama.net/documents/groundloop/basics.htmlhttp://www.jensen-transformers.com/an/an004.pdf
And equipment that has the signal ground directly connected to the equipment ground chassis ground sometimes is the cause of ground loops and hum.Take a look at the back power IEC inlet of the OPs Integra DHC 80.2.http://integrahometheater.com/model.cfm?class=Preamplifier&m=DHC-80.2&p=i No equipment ground pin. The equipment is built using double insulated AC power wiring. Only the signal ground is connected to the chassis.Can the Integra DHC 80.2 pass through a ground loop from an offending piece of equipment like an active speaker through the common signal ground of the pre/pro to another or other active speakers connected to the pre/pro? You bet if the amp uses an equipment ground and the signal ground is connected directly to the chassis. All that is needed is a difference of potential, voltage, to exist from one common equipment ground/signal chassis ground of one amp to the chassis ground/s of the another amp/s and current will flow back to the AC source causing the 60Hz hum.Problem I have with the OPs hum is the system worked fine in the new house before he added the new branch circuits. He said he hooked the system back up the old way and still had the hum. He had to change something else.... Maybe the OP will check his thread and answer my questions to him in a previous post.
are there any non-polarised ac plugs in your setup?? If so , trying swapping polarity on them.
I'm not sure what a non polarized plug is? Is it just a plug without the ground pin? How would I swap the polarity on them?
It wasn't me who said that, Jim. All my equipment has the case connected to mains earth, via the earth pin on the IEC socket.In my last system, yes, the arm had a ground wire which connects to the phono stage grounding post (which is connected to the case ... and therefore mains earth.) But this ground wire does not touch either of the signal 'ground' wires coming from the cartridge - it is there simply to ground the arm.In my current TT, there is no such earth wire - although the TT chassis is connected to mains earth, via the motor PS.Regards,Andy
Any suggestions on what to do here about the 80.2?I did have a friend over to help me diagnose the problem and it seems the loop is being caused by 3 different factors, I couldn't find myself as I would walk from one side of the room then back and couldn't hear the difference without being next to the speaker.The projector was causing some hum while plugged in......I now have run a extension cord to the power conditioner at the front of the room to clear up that bit of humThe cable into my time warner cable box was also causing some hum got that figured outThen the sub amps all cause a good amount of hum through the back speakers when switched on. The two face audio amps have ground lifts on them, when I lift the grounds it helps reduce the hum. The crest amp has no lift and adds a substantial amount of hum when switched on. The crest and the big face audio amps are on the 30 amp line
After rereading the post I do have a question for you. Are you sure none of your audio equipment also has the signal ground connected the chassis? Have you checked?Jim
For more on:'Why standard outlet testing methods fail to reveal reverse polarity bootleg ground miswiring situations'See this paper by Mike Sokel. Mike is a member of several pro-audio forums."Failures in Outlet Testing Exposed"Jul. 15, 2013 Mike Sokol | Electrical Construction and Maintenancehttp://ecmweb.com/contractor/failures-outlet-testing-exposed
