0 Members and 1 Guest are viewing this topic. Read 20337 times.
By the way, the amp sections of these old NAD receivers are fantastic. The pre-amp was the weak link that held these receivers back from a reaching legendary status.Wayne
I recently moved into a new home. I have an active 7 channel HT system using 6 subwoofers. 2 of the amps for my subs require a 30 amp outlet. I have had the system setup for a few months and everything was working great, no hum, some dsp hiss but otherwise all was good.I had an electrician out last week to add two dedicated 30 amp lines so I could get the subs running, and while he was there I had him add a dedicated 20 amp line.Upon turning everything on a horrible hum emanated from all the speakers. My first thought was it was my cable tv which I've had issues with in the past at different homes and that was not the culprit. I've now tried everything I can, have searched multiple threads on multiple websites and no luck. I'm starting to think its within the panel. Tap you can hear a hum at the panel where the breakers were installed. However when I turn the breakers off the hum is still in the speakers. I've tried unplugging the amps, turning off the breakers that were added and hooking everything up the way it was before the lines were added and still the hum. I dissasembled the whole system and started plugging everything in on by one. As soon as my pre/pro gets any type of signal be it from my CD player, cable box, etc the hum starts.Does this sound like a ground loop even . Does it sound like its from the breakers? The electrician doesn't think it is since when I turn them off the hum is still there. Thanks for any help.
..............................................The ultimate reference ground for your system and the house is the earthing rod - 10 foot long copper rod that is outside your house, just below the utility meter. This earth rod is connected to the service panel with a large gage bonding cable to bring low impedance ground into the house. Then all outlets are connected to this single source of ground so that voltage differences between outlets and appliances is minimized. Bad connections along the way can degrade the quality of ground to individual outlets and appliances. Code only allows ONE earthing rod on the house electrical system. ....................................... .........Sorry for the rambling length.
You seem to be ignoring comments made early on in your request for help about your new branch circuits being on different legs of your incoming service. Explain to your electrician you need all 3 circuits from 1 leg of your service. Ask him to install a sub panel just for these circuits. He'll probably tell you at that moment, he can't do it without rewiring your whole panel, and/or bringing another service feed into the house. I recently worked on a project that required bringing in another 200 amp service feed just for 2 channel audio (quad amped) and home theater (2 dedicated rooms) at someones home. 80 amps (dedicated) to a home theater from a 200 amp service panel may not even be possible. Are all the self powered speakers on the 1-20 amp circuit with all the electronics?
Read this article and get a non-contact voltage probe. http://ecmweb.com/contractor/failures-outlet-testing-exposed
Thanks for sharing this article Speedskater. I didn't know about the bootleg jumper trick as an installation short cut. Good grief . Is there a particular non-contact voltage probe that you would recommend to purchase, or do you think they are all about the same? They are certainly cheap enough as a must have tool for the toolbox.Also, as I understand the article, the non-contact voltage probe would detect a reverse polarity bootleg jumper at the ground terminal because ground is now hot. But what about a correct polarity bootleg jumper? The ground and neutral would still both be close to zeroVAC, wouldn't they? So, should I just use a voltmeter to make sure I don't measure exactly zero volts across neutral and earth ground?Thanks again for sharing.
