0 Members and 1 Guest are viewing this topic. Read 20153 times.
However, I have nothing invested in vinyl. My plan is to go out and buy a cheap, and I mean <$50, and also get a pair of used LPs (already checked and I found an LP of a CD I already have to compare sound) and see if I even want to get into this rabbit hole. I've heard people wax eloquent about vinyl and want to hear for myself. And unfortunately, I do not have any friends or know anyone in my area that has a record player to go listen.
I'm not sure if this topic should be here or in the Cheap & Cheerful circle. Please move it necessary.I've done some research, and I can see that the best choices if you really, really want to start vinyl and you're on a budget are the Pro-Ject Debut Carbon, Rega RP1 and Music Hall MMF2.2 TTs.However, I have nothing invested in vinyl. My plan is to go out and buy a cheap, and I mean <$50, and also get a pair of used LPs (already checked and I found an LP of a CD I already have to compare sound) and see if I even want to get into this rabbit hole. I've heard people wax eloquent about vinyl and want to hear for myself. And unfortunately, I do not have any friends or know anyone in my area that has a record player to go listen.I have a TAD-150 Signature which has a MM/ MC phono pre, so I'm good there (Opinions on the quality of this pre?).All that said, there's the following available locally for around my price:1. Hitachi HT-2022. Hitachi HT-20S3. Technics SL-QD34. Technics SL-Q200All are listed as perfect condition, and plug and play. Which of these would you suggest? Or would you suggest other models in the $50 range? I don't have to get into vinyl right away. So, if you suggest I look around for another TT - in my price range - I'm open to suggestions.Thanks in advance for your help folks.
I see several pitfalls with this approach. ... the aspects of vinyl that are so seductive.
Hey! If this were a few years... maybe 5-7 years back. You can pick up a decent '80s table for $50 and less , get new cart like Grado or Ortofon $30-35 or so and you got a decent start. These days $50 won't get you much to be honest. If you are not in a hurry than look around for older Rega. I have Planar 2 I bought back in 1997, it still work fine. Not much to go wrong with this type of manual TT. I have it in my second system now. And to answer you curiosity, yes LP sound better than CD.. most of the time. Not all LP album sound better than the CD version. And in fact some of the reissue LPs were cut from digital master or worst from cd by some greedy record companies. But if you ask me is LP worth getting in to? Definitely yes... if your table and cart are set up right, you clean and keep your LPs clean and have space for the growing LP collection. The last one is a bit of a problem for me since I in a rental apartment here in NYC Not sure where you are but if you are in NYC or will be in the area, you are welcome to check out my TT and system out. Take care,Buddy
Thanks for all the replies folks. It looks like my best best is to go new, and take a slight $$ hit if I decide vinyl isn't for me. The Denon DP-300F is the front runner right now, especially with the apparently worthwhile upgrades that LPGear is providing with it. I have to be honest though - that Pro-Ject Carbon is just so attractive (to me). But this is all about, sound, right?I'm in Arizona, but if I'm ever in NYC, I'll look you up SET man. Thanks for the offer though.Now, to figure out which provides a better sound - Denon DP-300F or the Pro-Ject Carbon. I already know where Wushuliu stands on this one.
A great buy just appeared on Agon, a Kenwood 770D, looks mint for $250. This table was near TOTL with a slot-less motor and 9 1/2" straight arm like the Graham Robin. It picks up at end of record. This is the table I have my Genesis 1000 on, pictured left. All you'll need is a good cart (med/heavy arm) and add some mass inside. I don't think it will last.... http://app.audiogon.com/listings/turntables-kenwood-kd-7700-2013-01-30-analog-08869 neo
Dual 1229 Turntable ... Seems to be working fine ... EXCEPT ... I could not get the start/stop switch to function smoothly. It might be that I just don't remember how it works. The tracking, skating, speed control, etc all work fine. The Empire 4000 D/II cartridge is in the unit now. The dust cover is with the unit and is intact EXCEPT for a couple scratch/cracks in the lower back of the cover. I do not know where to look for a serial number.Three cartridges. One is The Empire 4000 D/II,another is the SHURE M91ED,third is a Audio Technica AT Pro-11EAll three cartridges are in good condition.
What would you go for? The 770D or the 1229? If you think the 1229 is a better unit, how much would you offer this guy for the TT and the cartridges together?
