0 Members and 1 Guest are viewing this topic. Read 53833 times.
When I went to attempt to enable SSH on mine after registering it, there was no option for that in the security tab, anyone have any suggestions?BTW, I got mine from Adorama, also an EO2 model.
I copied this from the Vortexbox forum and it is from Andrew the guy who turned the pogoplug into a Squeezebox replacement."I loaded ArchLinux running on the POGOP21 I purchased. I loaded the precompiled ARM version of squeezelite and it works great!"So there may be hope for those of us who purchased the POGOP21 version. His link to the product on his website is the POGOP21 also.I am just to much of a computer dummy to probably make this thing work.
Randy,You may want to consider another wireless router (something cheap) set up as an AP/switcher and connect using the ethernet to the pogo box. I don't think you want to share USB controller between audio and wifi. There are all kinds of problem with the Rasberry Pi playing USB audio because the ethernet and audio share the same controller.Duc
4.8 Mbits/sec is actually only 1% of 480 Mbits/sec.But bandwidth is not the whole story. Computers vary in their USB chipsets and implementation, and sometimes multiple USB device contention can cause a momentary stutter or glitch. Not a problem for most devices, but definitely an annoyance for audio or video streaming.Steve
Got myself a Sansa 8GB drive. Lets see if this will work (fingers crossed!)
