0 Members and 1 Guest are viewing this topic. Read 53810 times.
I noticed to price has crept up the $25 now at adorama, for the "guaranteed" E02 model. It was $22 for the E02 when I bought it before.
Out of curiosity, I took a this ....thing apart.
Well, those pictures finally convinced me. I just ordered two of these from the VB store. I suppose I need a USB or ? DAC to get noise out of these.So what are the, as we say, value leaders?
You would need a WiFi router to talk to the Android Tablet.
Can't I just connect the tablet to the Pogo with a cable?
I don't think so. First, you need a router to multiply your one wired cable Ethernet outlet coming from the cable broadband modem into many wireless and wired DHCP Ethernet ports. If this makes no sense, you need to get some local help from someone who knows how to do this - it's not hard, but not really appropriate to give the tutorial *here* on how to set it up.Once installed, you can use many different devices for either servers or SB controllers, depending on what you have on hand. Most recent smart phones will certainly work as controllers, as will any windows PC (XP on...) for both server and controller. That covers a LOT of devices. Linux too, if you can turn that tool.
Thanks. I already have my PC/JRiver hooked up. No sense in being redundant.
What do you want to do with the Pogo?Where you planning to run JRiver from the PC, and then use the Pogo to just drive the USB DAC?If you gave us more information on what you want to do we could give you better advice.
