0 Members and 1 Guest are viewing this topic. Read 51738 times.
That Stoner Acoustics dac isn't just small, it's tiny. Quite interesting. BTW, has anyone seen a comparison of the Hifimediy dac vs. the ODAC?John
I ordered this one yesterday, $50 with shippinghttp://hifimediy.com/index.php?route=product/product&path=62&product_id=83DIYaudio thread on ithttp://www.diyaudio.com/forums/digital-line-level/219140-hifimediy-es9023-te7022-24-96-usb-dac.htmlFound this todayhttp://stoneracoustics.blogspot.com/head fi threadhttp://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odacI think it will take a couple weeks to get the hifimediy dac. Randy
Since it's USB, it should be powered by the computer.
I'll post my impressions of it after I get it.
A Sabre DAC at this price is intriguing.
People are plugging headphones straight into these?
I don't know how intriguing that really is just because it uses a ESS Sabre brand chip. ESS makes a variety of DAC chips from the most expensive 32-bit 9018 down to the entry-level 24-bit 9023 that requires a minimum of external parts and costs only a few dollars. $50 is a lot cheaper than $150 though, but that $150 does get you a California-built ESS 9023-based HRT Music Streamer II in a nice metal case with 5 sample rate LED indicators and company support, so I certainly wouldn't expect an import without those features to cost any more than $75 anyway. Steve
Are you sure the Streamer uses the Sable dac? I just searched, and found references to a TI dac inside the Streamer II. So I don't think the Streamer is really comparable.
On another somewhat related note, I decided to buy a set of the Monoprice 8320/MEP-933 IEMs. They are supposed to sound very good for the price, they were $9 with tax and free shipping on ebay (from monoprice), a little cheaper than buying direct from monoprice. Want to see if the hifimediy dac can drive them directly.
I don't know how intriguing that really is just because it uses a ESS Sabre brand chip. ESS makes a variety of DAC chips from the most expensive 32-bit 9018 down to the entry-level 24-bit 9023 that requires a minimum of external parts and costs only a few dollars. Edit: I had made a reference in this post that the HRT Music Streamer II used the ESS 9023 chip, but that appears to have been taken from an erroneous source, and further searching seems to indicate that it is in fact a TI DAC chip, so that reference has been deleted from this post. Steve
You are correct about Sabre manufacturing inexpensive DACs, but at this price point, I'd expect a no name Chinese brand.
