0 Members and 1 Guest are viewing this topic. Read 51735 times.
Sorry, if it helps I bought an Olimex too.A guy posted about this other one a couple of days ago at diyaudio
Where did we leave this? Is it worth my $50 for a Hifimediy USB DAC or should I double down and get a $100 DAC?http://hifimediy.com/index.php?route=product/product&path=62&product_id=83
What do you want to use it for?It's a nice, small dac which should sound better than your PC. It can drive IEM's directly, using windows to control volume digitally, which is nice.I think it's worth $50. I actually broke mine by applying too much voltage to it (long sad story) so I ordered another one.In the meantime, I built a "pupDAC", which probably sounds better, but is larger, and costs $120 in parts, and then I spend 5-6 hours putting it together. If you could buy one assembled, probably $200 or so as a guess.Randy
I want to use it to connect to my preamp from my Mac and PC instead of the headphone out jack. No DIY electronics for me.
Who is going to get one?
http://hifimediy.com/index.php?route=product/product&path=62&product_id=87
Someone please explain: If this is a Digital to Analog converter where does the coax out (digital) get used? Is it just a USB to Coax converter that by-passes the D to A conversion? Also, is the volume pot a worthwhile addition ( or hindrance) over windows volume control for use with an amp such as a Tripath board without a pot?
