0 Members and 1 Guest are viewing this topic. Read 53878 times.
Received mine today from Amazon and it is the P21 version. Has a T3 in the Product ID. Oh well, back it goes.
So it seems it's a roll of the dice with either Triplenet or Adorama. With my two orders I guess I increased the odds of getting a correct one by 100%. Fingers crossed!
Bob from St. Louis, you have a new software/hardware piece to bitch about.
Hi Bob:I've been thinking about the practicality of this device and whether or not its ready for prime time. I was messing w/ you but you would be a good test for whether a wider audience is a possibility.
Randy,Is it the black chassis or white/pink chassis E02 version?
My first mistake, went to Frys and a small 8gb stick was the same price as a 4gb one, so of course I bought the 8gb.Then, I read the directions more carefully, and you are copying an image to the stick, and it's a 4gb image, so it needs to be a 4gb stick.It does appear there is a way to fix this, but sticks are cheap so I am just going to buy buy a 4gb stick and I can use the 8gb stick for other stuff.Randy
You can use either 4g or 8g. No difference. Make sure you run as administrator, otherwise it will not copy properly.Duc
