0 Members and 1 Guest are viewing this topic. Read 111181 times.
The Mills just sound cleaner. Build yourself a test fixture that has a really, really good DPDT switch in it (you know - silver plated coin silver contacts) that you can use forever. Put a Mills and a boat on the legs running to a tweeter. You will hear the distortion as additional edge on transients like cymbal crashes, etc. I know that this is Mr. Empirical talking to Mr. Theoretical, but it really is an interesting experiment. Kind of like "Watch Mr. Lizard".
Here is one of the long standing op amp links. FWIW the most highly regarded opamps for audio at present are ones with distortion (THD + noise_ of around 0.00008% or below:http://tangentsoft.net/audio/opamps.htmlhttp://www.ti.com/product/opa2134http://www.ti.com/lit/ds/symlink/lm4562.pdfDave
Yup, or else you might end up like StigErik on DIYaudio with 8 21" in OB to get results. Or Monte Kay with his nutty OB arrays of how many Dayton Refs per side? No sense modulating the heck out of 150-200Hz with 1" P-P 40Hz, right? Greg
Plus, again, I already use Mills (and Mundorf) for reasons previously stated.
Well I could do all that Dave...but I'm afraid it wouldn't get us any closer to explaining why Brian heard drier sound varying resistors, in his sensing circuit...in his subwoofer.Plus, again, I already use Mills (and Mundorf) for reasons previously stated.Can't recall where I saw the one I referenced, but go over to the tubes circle and tell them ultra-low THD is preferred...and results in fuller, "wetter" sound .cheers,AJ
I think you've missed the point. The reason for using so many "Dayton Refs per side" is so you WON'T be operating them at 1" peak-to-peak. Thus lowering non-linear distortion. Dave.
Yeah, and StigErik doesn't get much lower than 20hz. That's why whenever someone says they are getting low bass with their OB system, I never believe them.
You wouldn't be the only person not to know what low bass sounds like. Why do you want to get lower than 20 Hz?
I'm flat to 12 Hz.
Sure I get that perfectly well, but just the fact that one may have to go to such herculean measures, makes my decision a little easier to let that last octave or 2 go to a boxed woofer. My system already takes up enough space, I do not need two additional refrigerators in here.
I think I missed this. Can you post the link?
Page 12 right under your post, since I can't figure how to do a direct link
I'm kind of like you in the enjoy the music mode. We could spend all of our time measuring things and little time enjoying the message.
Tubes and solid state really are apples and oranges. For music production, recording and mastering, I always use(d) the proper tool for the job. Can't beat an old LA2A or 1176 tube compressor, but a Grace, or Avalon mic pre is the deal. A lot of the new digital clones sound great, but not like the real thing. That fuller, wetter sound comes from tubes, not algorithms... certainly not from .0000000000000000000001%-ish distortion. I"m a second order guy
What do you pair your Soundfields with for low bass? They are great sounding speakers and go low well on their own. Do you use any augmentation?
What do you mean I don't know what low bass sounds like? Or should I say, feels like. Definitely been there. FWIW I do own music that goes that low, but it isn't Lawrence Welk.
Have you tried putting any of it through an FFT to see what's really on it? Give it a try, it can be quite illuminating. Audacity is free.
