0 Members and 1 Guest are viewing this topic. Read 111248 times.
Btw, I use Mills in my XOs, because I have found that some sand casts are not as non-inductive as purported...
Dave, are you able to run the relevant section of the track through an FFT? Might be interesting to see what's actually on it...
AJ, but inductance is insignificant at low frequency. It is a big concern only when you go up into khz frequency. Some amplifier even has an output inductor to achieve sufficient phase margin so that amplifier does not oscillate. Moving that inductance to the crossover does not make a difference. Is that the only reason you go with Mills? Can it be the Mills has lower temperature coefficient and it does not produces as much distortion modulated by resistance instaneous temperature? Or is it because the poor construction rigidity of sand cast resistors gives more micro-level vibration? You are asking a reason that there are all sorts of manufacturers internal documents of what works and what does not. I really don't know what you want to prove here and there. BTW, you keep mentioned this Clarity cap thing. I don't even know what it is. But that is not a basis for generalization.
AJ, but inductance is insignificant at low frequency. It is a big concern only when you go up into khz frequency. Some amplifier even has an output inductor to achieve sufficient phase margin so that amplifier does not oscillate. Moving that inductance to the crossover does not make a difference. Is that the only reason you go with Mills? Can it be the Mills has lower temperature coefficient and it does not produces as much distortion modulated by resistance instantaneous temperature? Or is it because the poor construction rigidity of sand cast resistors gives more micro-level vibration? You are asking a reason that there are all sorts of manufacturers internal documents of what works and what does not. I really don't know what you want to prove here and there. BTW, you keep mentioned this Clarity cap thing. I don't even know what it is. But that is not a basis for generalization.
Thanks, Brian. I'll try it. But I believe I need 2 controls in the PEQ: One to notch out a boost at 30Hz; the other to boost the 80Hz region.
The (in)famous LS3/5A had a 3-4dB peak at cabinet resonance (105Hz) to give the illusion of more bass.http://www.g4dcv.co.uk/ls35a/history.htmlIn the studio we recognize 60-80Hz to be a "mud range" that causes a lot of masking, but the range from 80-110Hz makes bass sound punchier without adding too much chestiness to recordings. Also, rooms with an 8' ceiling height have a pretty big bump at 71 hz to begin with. This could be partially responsible for you not really picking up on the 'smack' of a kick drum for example.Dave Dave
Danny lists Sd of that driver at 490 cm2. I question that but gave him the benefit of the doubt in the calculation.
The photograph makes it look the driver has a very wide surround.Measuring from middle of surround to middle of surround would yield a fairly optimistic number....IMO.Do you agree with numbers posted by myself and Erling?Cheers,Dave.
That is the industry standard for measurement. Center of surround to center of surround. Make no sense at all to me, but that is the way it has been measured since the mid 70's. Vance Dickason established the standard and it has been in place ever since.Dave
Yep, I'm aware of the industry standard.But these days we're surrounded (another little pun there) with drivers that have very large surrounds relative to the driver size. This introduces an error if measuring with the traditional method.Some of the manufacturers have adjusted for this and now measure cone width plus just one half of the surround width.Cheers,Dave.
