0 Members and 1 Guest are viewing this topic. Read 111303 times.
Oh yeah (quick edit here) the track is from Pete Belasco and is called Deeper. It's the second track on the album.
You really have to know AJ to get some of his posts. He and I were bitter enemies for years until we met each other and came to understand each other. Now I consider him a great guy and a worthy opponent/advocate in a discussion of differing points of view. He will pull someone's chain for sport with more than a little understanding of the topic at hand. Me? I've been known to pull the pin on the controversy grenade and roll it into the middle of a room myself. What is going on here is that there are some people that just don't want to admit that they don't know all there is about situational dependence in discussions. Probably on both sides. What we are trying to do is get to the bottom of a controversy that does not need to exist.Agendas are what they are: we ALL have them. That in itself is not a bad thing. It is when we are unable er, .... unwilling to admit this that these things get out of hand.Dave
Here is 35Hz and 40Hz. They are starting to drop off and level out now. Again this is typical for my room. The 25Hz or so peak for my room can be seen. Not a bad place for room gain. Even allowing for that you can easily see levels over 100db below 30Hz even at 20Hz. 35Hz hit 100db. And 35Hz and 40Hz levels could have been higher if I would have turned them up more. I had plenty of X-max left but didn't want to overdrive the amp, and at those higher frequencies I can't judge output levels by watching the woofer move. That reading at 20Hz of 105db was about the limit in my room. And please keep in mind that this will vary a lot from room to room. These would not hit levels like this in a huge room. And I am sure there will be some red herring in there somewhere that someone will come up with to say this isn't valid because of blah, blah, blah... oh well.
You're the one who claimed a dry sound, not him.
Brian and Danny, I would love it if you would stop avoiding questions like the ones poised by AJ of Soundfield Audio.
BTW-what computer do you use for your tests? Apple or Mac?
He wasn't talking to me.
If you are talking about Danny's CLIO plots, the CLIO system and software run on a PC. I have one here as well.
I am using a prototype DAC from db Audio Labs. I have been in the beta testing group for its development for the past year. Big strides have been made. No wait, "huge" strides have been made... I did A/B compare an earlier version of it to the Light Harmonic DaVinci DAC. That is another really good DAC. I think at the time it was $12k or something. The latest version is now $20k. So a bit pricey, but at the top of the performance chain.
My listening system uses a very highly modded Mac Mini.
Interesting. I ask as at RMAF I asked if you could play some tracks from my USB stick and you said that you didn't know how to do that as your not a Mac guy. That really shocked me and others that I've spoken to. Oh well.
The output impedance of the amp is lower than that. What I meant was the extra headroom on the amplifier has when it has only 13.5ohm load vs an ideal standard 4ohm loads.
What is it then?I performed a simple calculation on the numbers you quoted. How could it not be 1.6 ohms?Are you not attempting to make the amplifier as close to a voltage source as possible with this servo configuration?Cheers,Dave.
Unibox gives:It seems fairly comparable, although the excursion is higher (but 18mm at 20 Hz). One discrepancy is that I used 90W to get that excursion, whereas your screenshot seems to show 400W. I used Sd=479.2 as per your Klippel test.
I used a combination of current feedback and sensing feedback. It is not conventional stand alone amplifier that you can measure output impedance. If your 1.6ohms is used to model the headroom dependency on loading, then you can be onto something that I am not aware of and it can be quite useful.
Well, if the voltage measurements you quoted are correct then the output impedance IS 1.6 ohms. At least at those frequencies under steady-state conditions.This indicates a damping factor specification of only 2.5 for a four ohm driver and only 10 for a 16 ohm driver. (Or DF of 1.8 if a "traditional" damping factor calculation is used.)You quote a Damping factor of "160 @ 4 ohms" on your website."(Note: damping factor is speaker wires dominated. Without speaker wires, the native damping factor is >800)."That implies a very low output impedance. So, that specification does not agree with your quoted voltage readings in the previous posting.Cheers,Dave.
AJ may think gradient is the solution to good sound.
You may think it does not matter if it does not show on graph.
How about me? I think coheerent system that performs exactly same (even with distortion as long as the distortion is low order) at any moment of time is the most important thing. Even in a system with distortion, as long as it makes consistent and coherent distortion, it is better than otherwise.
Now you ask me what a "incoherent" sound will sound like to me, I can give you all kinds of adjectives, including "dry" depends on the type of incoherence and you cannot fault me and that is how an incoherent sound trick me to think.[EDIT] just to give everyone some perspective. Dave mentioned temperature coefficients (TC) of cement resistors can have up to 600ppm/per C. That is 0.06%/per C. Typical distortion of power amplifier these days is 0.02%.
