0 Members and 1 Guest are viewing this topic. Read 45404 times.
Those should be a winner, but the site says Euro 230V only. Also, not available through the dealer network.
1500 volts on the plate
I read each mono amp net weight 30kg, and 75kg both monos ready to ship.I believe it are 3 boxes, two amps and one box for the tubes;The GM70 tube start working with minimum 800V DC. So 850V also is a point used to delivery 20 to 25W output.
Impressive. For you guys with a lot of tube experience, how does something like this compare to a simple (but similar high quality) push pull amp using el34, kt88 etc.. tubes? Is it worth the huge and VERY expensive OPTs an amp like this requires, not to mention 1kV HV power supply...
A GM70 graphite plate power amp with volume pot to be driven by a DAC/CD player:http://lampizator.eu/NEWDAC/Lampizator/AMPLIFIERS.html
Love that GM70 tube. However like everything else one must hear it to decide. Input impedance is on the low side. One is required to use CDP direct no preamp ? charles
hi,..,.thanx,...the socked looks ceramic to me ,...i dond know the brand, sorry,...is it important ?...,i have some photos and i guess i have to update my gallery.the amps can be used with any pre amp, i use it with my dac directly plugged in to the monos but my dac has a volume control and its a pre amp at the same time....pre/dac kind of thing.
