0 Members and 1 Guest are viewing this topic. Read 36697 times.
(3) Keep all HT / Audio dedicated lines on the same phase at load center. Make sure dirty stuff like AC / refrigerator / etc are on another phase.
..at least have the refrigerator and any other potentially noisy 120 appliances on another phase...........or does this really matter in the end?
************ Now my questions, I will have 5 amps , 3- GR Research sevo amps ( 1 in each speaker and 1 in sub ) and 2 Ncores, can I put all 5 on same 30 amp circuit or should I run 2 circuits? I'm running cryoed 8-2 w/gr romex ,30' runs also sub panel parts and breakers will be croyed. my only source that runs on A/C will be my dac, everything else is battery powered, should dac be on its own circuit? Would it help to run ground from sub panel straight to ground rod instead of to main ground bar? I'm hard wiring all A/C equipment, no plugs or receptacles, except for the sevo amps for right now, ********* Any suggestion will be appreciated. Mike
Quote from: jarcher on 5 Sep 2012, 06:10 pm(3) Keep all HT / Audio dedicated lines on the same phase at load center. Make sure dirty stuff like AC / refrigerator / etc are on another phase. While the refrigerator and other 120V appliance circuits will connect to one side ("phase") of the panel, the "dirty" A/C and other 240V circuits will connect to both sides. Nothing you can do about that. Steve
Theoretically the dirty circuits should come first. But the difference is extremely small. The shorter the bus-bar the less voltage drop the dirty noise currents will have.
