Dedicated Power Line Recommendations - REPRISE!
0 Members and 1 Guest are viewing this topic. Read 36690 times.
mcallister
Re: Dedicated Power Line Recommendations - REPRISE!
« Reply #80 on: 31 Mar 2013, 06:26 pm »
I highly doubt it would need the 30A line, I was going to wire for one mainly because the amp is wired with a 30a connector.
Do you think the 3000VA can even get the job done? Should I just use a seperate sub panel and forget the Plitron? I will be able to place the sub panel and Plitron if needed just outside the listening room.
Thanks for the help!
Speedskater
  • Kevin
« Reply #81 on: 31 Mar 2013, 06:52 pm »
What model Plitron?
mcallister
« Reply #82 on: 31 Mar 2013, 06:53 pm »
Sorry the Plitron is the 3000va
Speedskater
  • Kevin
« Reply #83 on: 31 Mar 2013, 06:55 pm »
For other readers doing serious wiring projects, they total about 145 pages, but are well worth reading:
The Bill Whitlock of Jensen Transformers Seminar paper
http://www.jensen-transformers.com/an/generic%20seminar.pdf
The Jim Brown of Audio Systems Group white paper
"Power and Grounding for Audio and Audio/Video Systems"
http://www.audiosystemsgroup.com/SurgeXPowerGround.pdf
"Power White Paper" from Middle Atlantic.com
http://www.middleatlantic.com/power.htm
Speedskater
  • Kevin
« Reply #84 on: 31 Mar 2013, 06:56 pm »
Do the Plitron have a part/model number?
mcallister
« Reply #85 on: 31 Mar 2013, 07:00 pm »
6130-V1-003000VA
Here is some info on it if it helps.
6130-V1-003000VA Medical Isolation TransformerOutput: 2 X 120VAC @ 26.09A in parallel,1 X 240VAC @ 13.04A in series,Temperature Rise 60C,Leakage current 8uAQuantity:
Speedskater
  • Kevin
« Reply #86 on: 1 Apr 2013, 02:01 pm »
OK, it's a little tricky, from the main panel run 30A wire to the 30A receptacle, but only use a 25A breaker (the f2000tx amplifier will just have to get by on 25 Amps). tap from the receptacle to the Plitron input. Wire the Plitron's outputs in parallel to a little two breaker box. Use two 15A breakers in the box.
Notes: My drawing lists the Plitron's input at 120V but the output at 115V.  It would have been more fun if the outputs were 15A.
We have to wire the circuit as a 30A circuit in order to connect a 30A receptacle. Then we undersize the breaker to connect the Plitron. This needs a warning label in the main panel.
mcallister
« Reply #87 on: 1 Apr 2013, 09:44 pm »
Thanks speeds later greatly appreciate it!
Speedskater
  • Kevin
« Reply #88 on: 1 Apr 2013, 09:54 pm »
What type of in-wall wiring do you have?
Romex® Non-Metallic
Metal Conduit EMT
Metal Flex
Plastic conduit
Print out the appropriate parts of the Middle Atlantic paper to show the electrician.
mcallister
« Reply #89 on: 2 Apr 2013, 12:34 am »
I haven't decided yet. I'm still not in the house. What would you recommend?
Speedskater
  • Kevin
« Reply #90 on: 2 Apr 2013, 01:03 am »
You my not have a choice.  What city/state is it in?
mcallister
« Reply #91 on: 2 Apr 2013, 10:25 am »
Dayton, Ohio
Speedskater
  • Kevin
« Reply #92 on: 3 Apr 2013, 01:02 pm »
You're just a few hours down the road from me.  I think that Dayton is standard NEC code (no special restrictions). You don't want plastic conduit, but the other 3 are a toss-up depending on the actual product and installation technique. Is a paid electrician doing the work or you & friends?
