0 Members and 1 Guest are viewing this topic. Read 36685 times.
Using flexible metal conduit and grounding it helps to shield if you have a lot of signal running around the house...
To be code compliant you will need to use 20A breakers for 20A rated receptacles, if you use a 30A breaker you would need to fuse down to 20A to use a 20A receptacle.
To wire 2 receptacles would it be better to use 10AWG/2 NMB, 10AWG/3 NMB or run two separate 10AWG/2 NMB lines (one for each receptacle)?
Can you elaborate please on the benefits of flexible metal conduit & grounding it. On one of the other threads here I had read that it is code in some states and not in others. My electrician mentioned it once, but it seemed to be mostly useful when the wiring was going to be outside / buried / what not & needed extra protection. As this dedicated line is going to be purely indoors, running the romex through flexible metal conduit didn't seem warranted.
f] The idea of putting digital devices on a separate power circuit has been overtaken by events.
