Internet Radio on BDP-1?
0 Members and 1 Guest are viewing this topic. Read 24370 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 7 Mar 2011, 09:22 pm »
Hi Folks,
We are considering adding a few internet radio stations to the software in the BDP-1 Digital Player in the next release.
We are looking for 5 quality recommendations available through:
http://dir.xiph.org/index.php
or
http://www.shoutcast.com/
james
Phil A
Re: Internet Radio on BDP-1?
« Reply #1 on: 8 Mar 2011, 12:21 am »
James - did not look at the links but I have a Pioneer 1120 Receiver in the office system and below is what I programmed on it.  Most of the time when I surfing I have it tuned to Linn Jazz and I often listen to that on the Squeezebox Touch in the main system too.  Many of the below URLs were obtain through Shoutcast.  I tried for the most part to get the higher quality ones.
Linn Radio http://89.16.185.174:8003/stream
Linn Jazz http://89.16.185.174:8000/stream
Linn Classical http://89.16.185.174:8004/stream
http://yp.shoutcast.com/sbin/tunein-station.pls?id=1104998
 ~bEE Jazz
http://yp.shoutcast.com/sbin/tunein-station.pls?id=297075
Raritan Bay Oldies
http://yp.shoutcast.com/sbin/tunein-station.pls?id=1473791
SEOUL FM!
http://yp.shoutcast.com/sbin/tunein-station.pls?id=154
Happy Rock Radio
http://yp.shoutcast.com/sbin/tunein-station.pls?id=148269
Raven Radio Mix
http://yp.shoutcast.com/sbin/tunein-station.pls?id=1450622
Freebird Classic Rock
http://yp.shoutcast.com/sbin/tunein-station.pls?id=1423118
FM 101 Country
http://yp.shoutcast.com/sbin/tunein-station.pls?id=1088332
Delmondo Alternative
http://yp.shoutcast.com/sbin/tunein-station.pls?id=925018
CharlesRadio Rock
http://yp.shoutcast.com/sbin/tunein-station.pls?id=602507
Master Baker Rock
http://yp.shoutcast.com/sbin/tunein-station.pls?id=488461
4 Noises Pop
http://yp.shoutcast.com/sbin/tunein-station.pls?id=237552
Sunny Radio Classic Rock
http://yp.shoutcast.com/sbin/tunein-station.pls?id=165878
New England Jazz Express
http://yp.shoutcast.com/sbin/tunein-station.pls?id=76546
RTi FM Top 40
http://yp.shoutcast.com/sbin/tunein-station.pls?id=38991
CruiseOne Pop/Rock
« Reply #2 on: 8 Mar 2011, 11:47 am »
Thanks Phil
Yes I thought it would be nice to offer maybe 5 or 6 preloaded stations of the best quality with different content mix.
James
BrysTony
« Reply #3 on: 8 Mar 2011, 12:41 pm »
Anyway to get it to play Pandora so that the user could choose his/her preferences?
Tony
« Reply #4 on: 8 Mar 2011, 01:19 pm »
Tony
[/quote
hi tony
Maybe in the future.
James
werd
« Reply #5 on: 8 Mar 2011, 02:08 pm »
James
Why don't you do a internet radio/HD combo unit? You are looking to mate an HDD with the bdp aren't you? Put a dedicated internet radio tuner on it.
Phil A
« Reply #6 on: 8 Mar 2011, 04:18 pm »
James
I guess that is the idea of the new Marantz piece, DAC, Internet Radio, streaming.  I'm not sure it is Bryston's niche.  I picked up the Squeezebox Touch at a 40% off deal and have an upgraded power supply for it and I can tell you it sounds really good on internet radio going through the BDA-1
Alpha10
« Reply #7 on: 8 Mar 2011, 08:19 pm »
Internet radio would be good for me on the BDP-1, an excellent value add.
Cheers
« Reply #8 on: 16 Mar 2011, 12:16 pm »
Hi Folks
I have about 10 Internet radio stations loaded on a beta software on my BDP and so far so good.
The list of available stations shows up as the call letters under the heading RADIO 1 under Playlists in Bryston MINI or MAX or MPOD or MPAD etc. When you click on a station the song and artist will show up and you can scroll through the stations listed exactly like you would with a song playlist.
You can also create you own list of stations say Radio Favorites with just the stations you want to listen to on a regular bases. Because you can only use the list included in the internal software how many stations do you think we should include?  I was thinking maybe 10 of the top recommended stations?
James
PS - the Bryston BDA-1 DAC decodes the Internet radio stations at 44.1 which you can upsample to 176/24 if you want.
Alpha10
« Reply #9 on: 16 Mar 2011, 12:55 pm »
Hi James,
Could you just clarify for me these lines "You can also create you own list of stations say Radio Favorites with just the stations you want to listen to on a regular bases. Because you can only use the list included in the internal software how many stations do you think we should include?"
I am not sure if you meant you will only ever be able to listen to the pre-fixed radio services but could just do a favourites list from them, or you have say 10 slots available and you can then browse for whichever station you like under that?
For example in the UK BBC - talk sport is one I use but would not be of much interest to most of the rest of the world, would I be able to make that one of my 'stations'?
On this note, are there geographic restrictions on some stations, you may want to be sure that any you pick if they are fixed are playable in every county you sell to?
Regards
« Reply #10 on: 16 Mar 2011, 02:01 pm »
Hi James,
Regards
Hi Alpha,
Yes the 10 stations are set in software so you have to pick from that 10.... say 3 you generally listen too and you can put them in a separate list if you wish.  Had not considered the geographical issue - interesting.
james
terrycym
« Reply #11 on: 26 Mar 2011, 06:40 pm »
Any chance of JazzFM?
http://www.jazzfm.com
« Reply #12 on: 26 Mar 2011, 06:44 pm »
Hi Terry - i will see if we can include it - we have adore jazz which sounds good :thumb:
Alpha10
« Reply #13 on: 26 Mar 2011, 08:21 pm »
Do you have the candidate list for public scrutiny yet?
terrycym
« Reply #14 on: 27 Mar 2011, 08:55 am »
Nice!
joey116
« Reply #15 on: 27 Mar 2011, 12:09 pm »
Hi James, will it be possible for the user \ owner to program their own favorite 10 channels  into the BDP-1 ?
« Reply #16 on: 27 Mar 2011, 12:53 pm »
Hi Joey,
No sorry - the radio stations links are part of the new software - so the 10 or 12 we give you can be put into say you're favorite 5 stations as a Playlist but the original stations are set.  Now we can change them going forward over time with new software so what I am hoping is we can have a consensus on which 10 stations people like best and we will offer them as a standard download?
The Internet Radio stations show up as a Playlist (Radio 1) on your interface.
james
joey116
« Reply #17 on: 27 Mar 2011, 01:01 pm »
Thanks James, it's a great added feature to the BDP-1, am I correct though that perhaps it's not replacing an internet radio tuner, for someone that wants to surf the 1000's of internet radio stations?
« Reply #18 on: 27 Mar 2011, 01:45 pm »
Correct for those wanting to surf the Radio Internet the BDP is not the right choice.
James
Stu Pitt
« Reply #19 on: 27 Mar 2011, 03:42 pm »
I don't mean this the wrong way James, but why limit it to what Bryston has chosen?  If you ask 100 people what their top ten are, you'll get 1000 answers.  While frustrating for you guys, it's even more frustrating for the buyer.  Wouldahoy buy a Magnum Dynalab tuner that only gets 10 stations that the manufacturer thinks you should listen to?  A car stereo with the same issue?  I say go all out Internet tuner or not at all.
I know the BDP-1's primary function isn't Internet radio.  That feature is more of a convenience than anything else.  But if you're contemplating adding it, do it right IMO.  Not to mention, what'll the hifi rags say about that in a review?  I'd imagine they'd say how hard would it have been to add full Internet radio. I think everyone but the most die hard Brystonites would have a problem with it too.
