Internet Radio on BDP-1?
0 Members and 1 Guest are viewing this topic. Read 30562 times.
Vipers
Re: Internet Radio on BDP-1?
« Reply #60 on: 11 May 2011, 09:46 pm »
I revisited the internet radio tonight on the BDP-1 as last time I had some streaming issues, it all ran fine tonight and I have to say I'm amazed at the audio quality of the stations chosen, at first I was a little unsure of only having 10 to flick through but as the ones chosen are of such high quality it takes out all the hassle of filtering the wheat from the chaff yourself.
The only problem is that I spent most of the night listening to 'Absolutely Country Hits'  :oops:
James, the channels chosen really offer a great spectrum of different music genres but is there any chance going forward that you'd consider adding maybe 'Planet Rock' or a similar station to cater for us old rockers out here  :)
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #61 on: 11 May 2011, 10:13 pm »
Thanks.
Hi vipers
Can you send me the URL
James
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #62 on: 12 May 2011, 08:26 am »
http://www.planetrock.com/
http://www.planetrock.com/listening-online-746041
(again, google is your friend...)
Awesome station, I listen to it at home all the time.
« Reply #63 on: 12 May 2011, 10:49 am »
thanks,
james
jjc1
« Reply #64 on: 12 May 2011, 04:18 pm »
Hi Folks
I have about 10 Internet radio stations loaded on a beta software on my BDP and so far so good.
The list of available stations shows up as the call letters under the heading RADIO 1 under Playlists in Bryston MINI or MAX or MPOD or MPAD etc. When you click on a station the song and artist will show up and you can scroll through the stations listed exactly like you would with a song playlist.
You can also create you own list of stations say Radio Favorites with just the stations you want to listen to on a regular bases. Because you can only use the list included in the internal software how many stations do you think we should include?  I was thinking maybe 10 of the top recommended stations?
James
PS - the Bryston BDA-1 DAC decodes the Internet radio stations at 44.1 which you can upsample to 176/24 if you want.
  James, how does one upsample internet radio to 176/24 on the BDA1? Also, does upsampling on the BDA1 have any effect on the music being played thru th BDP1?
« Reply #65 on: 12 May 2011, 05:08 pm »
Hi
To up-sample just push the up-sample button on the BDA-1.  It does not affect the BDP-1.
james
jjc1
« Reply #66 on: 12 May 2011, 05:38 pm »
Hi
james
Does the upsampling work incremetally or does it automatically got to 176/24 when you are tuned into internet radio? Also, when using a cd player thru the BDA1 pushing the upsample button, does it only upsample to 192 or can 96 be had? I'm only asking because my BDA1 is only 2 weeks old and I'm not sure how to operate itjust yet. I had a Cary CD player that I could upsamle all the way to 768 and each push of the button was incremental.
« Reply #67 on: 12 May 2011, 05:46 pm »
If you push the UPSAMPLE button on the front panel then the incoming digital signal will be ‘SYNCHRONOUSLY UPSAMPLED’ and turn (Green or Amber)depending on the incoming sample rate. (Green if the incoming is 48 or 96K and Amber if 44.1 or 88.2K)
If the sample rate coming in is 44K or 88.1K the BDA-1 upsamples to 176K
If the sample rate coming in is 48K, or 96K the BDA-1 upsamples to 192K.
The upsample feature works on all inputs (including the I2S USB input) assuming the Upsample button is push.
If the incoming signal is 'native' 176K or 192K then no upsampling occurs.
Hope this helps explain it better?
james
jjc1
« Reply #68 on: 12 May 2011, 06:11 pm »
james
So the upsampling will automatically go to 176k or 192k depending on incoming signal if the button is pushed. Will playing a file ripped from a CD to a USB drive with a sample rate of 44k and played thru the BDP1 be upsampled to 176 if the button is pushed? I assume not from your earlier answer.
« Reply #69 on: 12 May 2011, 06:23 pm »
Yes any input to the BDA-1 (from any source) at 44.1 will get up-sampled to 176 if the up-sample button is engaged.
james
« Reply #70 on: 12 May 2011, 06:24 pm »
Hi vipers
James
Hi Vipers,
If you reboot your BDP-1 Plant Rock should be there as the 7th station :thumb:
james
konut
« Reply #71 on: 12 May 2011, 06:40 pm »
  The upsample feature works on all inputs (including the I2S USB input) assuming the Upsample button is push. james
Sorry for going OT but I couldn't let this go. The USB input also accepts I2S? Has this been discussed before? Isn't this kind of a big deal?
jjc1
« Reply #72 on: 12 May 2011, 06:48 pm »
james
O.K. Think I've got it now.  Thanks James for your usual prompt and insightful response.
Alpha10
« Reply #73 on: 12 May 2011, 06:52 pm »
Hi Vipers,
james
Vipers, let us know how you get on, I would like Planet rock added to mine as well  :D
Cheers
« Reply #74 on: 12 May 2011, 06:57 pm »
Yes it is important. What we do on the USB input is come in I2S and use the quality up-sampler in the BDA-1 to do the up-sampling.
james
« Reply #75 on: 12 May 2011, 07:20 pm »
Cheers
Hi Alpha,
Reboot yours and it should be there.
james
BrysTony
« Reply #76 on: 12 May 2011, 07:27 pm »
Worked for me  :thumb:
Tony
Alpha10
« Reply #77 on: 12 May 2011, 07:38 pm »
Hi Alpha,
james
Brilliant, that worked a treat. reporting 64 kbs but sounds very good indeed, you have just made my wife's evening, which in turn makes my life much easier, thank you.  :thumb:
Cheers
Vipers
« Reply #78 on: 12 May 2011, 09:58 pm »
Hi Vipers,
james
James, what can I say, unbelievable service, thanks ever so much, you're a star.
Let's Rock  :icon_twisted:
saveloy
« Reply #79 on: 13 May 2011, 10:31 am »
James,
I have feelings of envy. Could I too possibly have Planet Rock?
Kyri.
