BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
0 Members and 3 Guests are viewing this topic. Read 589851 times.
artur9
Re: BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
« Reply #1240 on: 16 Mar 2017, 10:24 pm »
How did you set that up? Did you manually install upmpdcli on the BDP-1?
I have a "home-made" NAS powered by an old MacBook Pro running linux.  I installed upmpdcli and minim server on there.  Although it doesn't matter where upmpdcli is running.
artur9
« Reply #1241 on: 26 Mar 2017, 04:01 am »
I played some music off a thumb drive on my BDP-1.  Nice!  It also displayed artist/album correctly on the front panel.  Wish I could configure it to do that for HTTP streams.  No value to me that second line that says "HTTP".
I do have a question.  How does one do a factory reset on a BDP-1?  There's some cruft from the previous owner I'd like to clear out.
Krutsch
« Reply #1242 on: 26 Mar 2017, 04:25 am »
Go into the "System" tab and click on "Reset To Factory". That's it.
Krutsch
« Reply #1243 on: 26 Mar 2017, 04:26 am »
Honestly, it's how the BDP-1 sounds best.
artur9
« Reply #1244 on: 26 Mar 2017, 03:15 pm »
I was listening to Glenn Gould's 1982 Goldberg Variations needledropped from LP.  Sounded fabulous!
Even over the network the BDP-1 bests my turntable (admittedly, my preamp digitizes everything so...).
Krutsch
« Reply #1245 on: 26 Mar 2017, 03:48 pm »
I do that, as well. I have a Bel Canto DAC/digital pre-amp that I plug in the analog output from my phono stage; it's for convenience, but I wonder if I am losing something not directly cabling into my headphone amp.
werd
« Reply #1246 on: 17 Apr 2017, 04:16 pm »
So, what are we using now to control a bdp with an ipad  or iphone? Now that Mpad is no longer updated or useable.
zoom25
« Reply #1247 on: 17 Apr 2017, 05:26 pm »
I use Manic Moose on iPad. I'm not into the loop of what new apps are good these days.
werd
« Reply #1248 on: 17 Apr 2017, 05:53 pm »
Thanks, i guess for $7.00 there is Soundirok at the App store.
zoom25
« Reply #1249 on: 17 Apr 2017, 08:22 pm »
Thanks. I've seen it mentioned here frequently. I'll look into it if I move the BDP-1 to my main rig. Right now the BDP-1 is used on the desktop rig, so I have an iMac in front of me to use Manic Moose.
The only problem I have is that I cannot add more than 300 songs to the list. I tried changing it from the settings in Manic Moose and altering the MPD Version number, but it does nothing and remains at 300. The capacity of 300 isn't a big deal, but rather which 300 gets added. For example, I have a few compilation playlists of over 800 and whenever I click add to the playlist, it will always add the first 300. If I wanted to automatically add tracks 301-600, there isn't a way I am aware of. I can only add them manually one at a time.
If anyone at Bryston has a solution, that'd be helpful.
unincognito
    • bryston.com
« Reply #1250 on: 17 Apr 2017, 08:46 pm »
you should make sure you have the newest firmware installed, some previous releases have broken this feature in the past, as far as I am aware S2.32 and S2.33 are working correctly
klao
« Reply #1251 on: 19 Apr 2017, 03:44 pm »
Hi James & Bryston team,
My BDP-1 (s/n 221) with software R02.0 2010-10-19 keeps getting Error 09 / 190.
Please help.
Thank you,
Klao
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1252 on: 19 Apr 2017, 03:49 pm »
Please help.
Thank you,
Klao
Hi Klao
09 means the system board is not responding - it would need to be serviced.
james
klao
« Reply #1253 on: 19 Apr 2017, 06:25 pm »
Hi Klao
james
 :cry:
Thanks, James.
Misl
« Reply #1254 on: 30 Apr 2017, 11:05 am »
Bryston BDP-1 + Tidal app
I have subscribed to Tidal and am presently surprised by the choice and sound quality offered. Probably I am doing something incorrectly with the Bryston's Tidal app, admittedly still in its Beta version. When I choose search in order to see an overview of available albums, such as, say, Eric Clapton or similar, I always get exactly 10 albums shown, not a single more. When I search through the Tidal app on my Nexus 10, I easily and almost instantly get tens and tens available albums. However, I definitely prefer to use MPD and the Tidal app in Bryston and, not the BDP-1 set as DLNA renderer. What am I doing wrong?
Misl
« Reply #1255 on: 30 Apr 2017, 11:31 am »
Perhaps I should add that I have the newest firmware S2.32 installed.
unincognito
    • bryston.com
« Reply #1256 on: 30 Apr 2017, 11:17 pm »
There should be an icon to load all the albums (a plus)
Misl
« Reply #1257 on: 1 May 2017, 03:14 am »
Yes, of course, the icon is there but clicking on it produces no effect - I have only ten items in each playlist, artists, albums and tracks sections and pressing on 'show all' does not change anything in either of them
unincognito
    • bryston.com
« Reply #1258 on: 5 May 2017, 10:37 pm »
It appears to be functional, you could place the bdp into service mode and email me the service id.  which browser/device are you using with the BDP?
Chris
Misl
« Reply #1259 on: 6 May 2017, 03:56 am »
Hi Chris,
I found the way how to make it work. Sorry for bothering you and thank you.
M.
