0 Members and 1 Guest are viewing this topic. Read 227611 times.
I was thinking that the Felix is a super-simple PCB idea. I'm not sure if the small volume would bring the costs down enough to make it worthwhile, but it would make mounting easy. Here's a quick first pass at one using ExpressPCB:This one is based on the Vishay 1778 X2 caps and the Coilcraft Combination CMC, but I just did a revision that also has pads for the JW Miller 8109-8121. Looks like costs would be ~$10 each for 20+ from ExpressPCB.
i would order 10and silverplated would be nice can those paths carry 2A?doesn't it need 4 holes in the corner? That would help me
Very nice! In a perfect world the .01Uf caps would be located as close as possible to the cmc's though, on the underside perhaps?
FYI: I realized this morning that my spacing was all messed up for the CMC and the 1.0uF cap, so I'll have a new one posted tonight. The lead spacing was correct, but I didn't leave enough room for the part itself - classic rookie PCB design mistake. Some questions for the group:To what degree should other sizes of caps be accommodated? The current layout handles Vishay 1.0, 0.1 and 0.01 uF caps. To a certain degree other values in the Vishay line will fit, but some will not. For example, I don't think the 0.47uF one fits in the current largest cap position. Is there another major brand of X2 that needs to be accommodated? (I looked at Wima, but no one seems to stock their X2's). It looks like I can fit pads for both the CoilCraft combo and JW Miller 8100 series, which seem to be the two popular options. I'm willing to say that's sufficiently flexible - agreed? CoilCraft also makes an equivalent to the JW 8100, but I haven't seen anyone use it here.Ground line: is it needed or does it make the board wider for no reason? Having a straight ground trace makes installs look cleaner, but doesn't serve a functional purpose. Should it stay?Optional fuse mount - Is it worth squeezing in a mount point for an option fuse on the board? If so, what are your preferences on type? I haven't tried this yet, so I don't know if it will be a pain to fit in. I would be very happy with thisParticular board size - should the design be made to a particular board size to allow using a particular case with rails (e.g. extruded aluminum options like the Hammond 1455)? yes this would be nice (for me) if it will perfectly fit a standard shielded caseMy prior question: Is an additional step of input side points for H and N worth doing to accommodate daisy-chaining? Or does this just set up the design to have current overload issues.
QuoteOptional fuse mount - Is it worth squeezing in a mount point for an option fuse on the board? If so, what are your preferences on type? I haven't tried this yet, so I don't know if it will be a pain to fit in.That would be a really neat thing to have on the output side of the board. Would people need the input side as well? I tend to use appropriate size breakers instead of fuses on the input side.
...the Miller's are definitely of a higher build quality.
