0 Members and 1 Guest are viewing this topic. Read 227580 times.
Quote from: JoshK on 24 Feb 2006, 08:44 pmDOS,Paul gave me a pair of CMCs to play with. We haven't experimented with size (uH) to know what works best, or even what value caps work best. It looks as though the Adept uses a plethora of varying sized caps. Who knows what size cmc they used. We need to experiment, hence the word "project". Here is the schematic: Mains in > fuse > [ x2 cap > cmc > more caps > outlet ] put as many of the [ ]'s that you want outlets in parrallel.Hi It has been sime time now. Is it still in this "project phase?
KyrillI think what the plot shows is the self resonance of that style capacitor in different sizes. The capacitor model being a series RLC circuit. Below resonance the capacitor is "capacitive", at resonance where XC=XL, it is just resistive, and above, it is no longer capacitive but inductive.Use the capacitor at frequencies below the resonant dip.Bill A
...So for the most effective way to deal thru out the audio band is to get multiple CMC but make sure they are different core materialIron core powder or something along this line made by roxbury is good from 50hz to 440hz as per their data sheet. I don't think there is much material that covers 500hz to 5Khz. I may not be aware of it but above the the 5khz there is alot of materials that can be found. Ferrites, permalloy and etc. You can check their data sheet of the material of the ferrite and check their impedance to see which zone they are filtering inPerhaps one way to do filtering via CMC in the audio range is to wind it on a double bobbin and filled up with EI core material or C-core using thin lamination like z11 or m6 minimum. I know the Z11/m6 would be able to work well in the audio rangeBest way to experiment for best filtering is to wind your own CMC choke. Its a no brainer anyway. The wires need to be Insulated to 180 Celcius or double insulated type, wind them in opposite directions and thats all. Find surpluss core material for various frequency filtering
Can this Felix design be adapted to handle higher currents (like for a 200 W/ch power amp)? Thanks again guys.
Quote from: StuntHunt on 4 Feb 2008, 06:40 pmCan this Felix design be adapted to handle higher currents (like for a 200 W/ch power amp)? Thanks again guys. Welcome to AC ShuntHunt! I've 10a Coilcraft Felix's built into each of my monoblock amps as my transformers pull about 5a max each. The size of your ps will determine whether you need to go to a 17a Miller or not but, if it's a stereo 200w amp, it would probably be best. About a year ago I built a rig using 3 - 4pdt NKK switches to compare two 10a Felix's verses no Felix and to compare 5 sizes of caps in different configurations from 3 manufacturers, Vishay, PBB and Epcos. The cap sizes were 2.2, 1.0, .47, .1 and .01Uf. This was all set up so I could seamlessly switch caps/brands from my listening chair. Both a bridged 3886 chip amp and a Modwright 9.0 preamp were being feed by the Felix's. After maybe three weeks of swapping caps out I decided that no particular combo really stood out as better to my ears and in my location. Different but, not better. I concluded, perhaps wrongly, that the coils were doing 90-95% of the filtering and the caps were doing the supplemental polishing and I've built my filters accordingly ever since, for the most part .47, .1 and .01 chosen for practicality only.I decided not to use the PBB's because of practical reasons as well, the .47 cap was easily twice the size of the Vishay 2.2 cap, that simply didn't fit with my plans for building Felix's into chassis's and way too small boxes A month later my girlfriend decided she simply had to have her forced air negative ion generator in her living room. About 7 minutes later I got a phone call complaining about the static noise coming from her speakers. It was bad! I'm just guessing here but, if the music was playing at 75db, the static was only 10dB below it and in the 200-400hz range? I installed a 10a Felix into the system (a 45w chip amp, tuner and dvdp) and that seemed to knock down the noise by about 20-30dB or so but it was still there. I went home and grabbed another Felix and installed it in series, the static was then barely perceptible. Interestingly, when I moved both Felix's to feed the neg. ion generator it did an even better job. Again, I've been building most of my Felix's as doubles ever since. The concept was kinda proven also when I got a look at how the Isotek Nova units were built, basically a double Felix feeding a series of double Felix's each feeding an individual receptacle.Doesn't virtually every DVDP have a SMPS in it as well?
So, for these double Felix's, do you make them C network - CMC - C network - CMC - C network
Hi Randy, yes I'm using all 3 c networks, though in one case I only used the .47 in the middle position, that being Natureboy/Roger's original Felix. Some time ago we did a comparo with his front end equipment using the double 10a Felix for his dvdp, preamp and phono amp vs. three individual Felicia's and Roger prefered the Felicia's ever slightly softer presentation to the Felix's more truthful presentation (my words!) where I felt just the opposite. Are you using a linear supply for the SB? It'd be very cool if you could try both before committing!
Dedicated lines can be run in cord form, instead of through wall, if need be/allowed (domestic issues).
......If you have too many capacitors, like plethoras of them, you will eat a lot of power even when nothing is on. I see no reason to waste any if you can help it. I think it might even be appropriate to use a switch to turn off things that do not need any power when off, unlike a Squeezebox...
Another questions, breaker or fuse/s?
