0 Members and 1 Guest are viewing this topic. Read 48821 times.
Get on the build list asap. It ain’t cheap but, dollar for dollar, it is the most startling improvement I’ve made to my system in years.
If I plan to use upsampling through Roon or HQPlayer with their filters before sending to the DAC2.0 what DAC2.0 filter I should use? I wouldn't want to pass the data through filters twice. Can you elaborate a little on this?
Can you explain more about the Filters 1 and 2? Currently I prefer using Filter 2 finding that it sounds more analogue and less forward.
I read this from roonlabs discussion board: " .. They (DAC chips including AKM, ESS, Ti etc) almost all upsample PCM to high res DXD PCM rates internally and then convert to a DSD type file before outputting analog."Does this apply to the AK4497eq chip found in the DAC2.0 and if so what would be the optimal Roon or HQPlayer upsampling frequency to keep the upsampling in Roon or HQPlayer without it being done a second time in the chip before converting to analogue?
- Oh by the way, the cracking noice at higher upsampling frequencies may have been caused by older microRendu software. Sonore tend to update their firmware but keep the version numbers the same and so you don't know if there is an update until you try to force the check. I updated from 2.5v to 2.5v (there were many file changes reported) and the cracking noice is mostly gone even at DSD256. Will continue to observe and test more.
A bit like plasma TVs compared with OLED 4K HDR screens. The latter is super sharp with super rich colours and detail but I much prefer the more natural feel of the older generation of plasma TVs.
Hi iSAMFrom your pic I think I see some SOtM boxes. If so, do they make a difference with the DAC2.0 with the new clocks and isolation technologies?
Hi,Yes, i use SOtM's with Uptone ISO Regen. I added each module step by step. And made several experiments with their combination with DAC2.0. My conclusion is that each element before DAC2.0 has a very significant value! Yesterday i installed the Curious USB cable. It is very difficult not to hear the improvements that he brought I plan to continue to improve my source further. DAC2.0 has a huge potential and everything you use before it will only reveal it.
Hi iSAM,I seem to have about the same boxes with sotm sms-200 ultra and the TX-usb ultra and ISO Regen. The problem for me is when the ISO Regen is in the chain either between the sotm or last in the chain right before the DAC 2.0. With the ISO Regen I get unprovoked shutdowns and I have to restart the LIO. But you are right all boxes before the DAC is of use for best SQ. Can you tell me how you have setup the chain and or if you have the ISO Regen in ISO defeat position or not.Thank you!Magnus
Did you guys measure any of these claims or they were based on a blind A vs B comparisson?https://audiosciencereview.com/forum/index.php?threads/usb-add-on-devices-measurements-including-regen.1270/I use DAC 2.0 only, and it is so good that things like my mood, time of day, wine or not etc. are the only things that can alter my perception of music.
Have only listened for 30 minutes in filter F2 mode, and It sounds absolutely gorgeuos. Compared to the previous dac its like the famousveil slowly dissappears. You got punch , definition, improved tone, yes the list goes on.Thanks Vinnie, good work.Back to listening....Cheers /Magnus
What amazed me from the very beginning is how revealing the DAC 2.0 is. It will pull out the maximum amount of detail from any sound file and you'll definitely hear elements of music that you've never truly heard before. After dialing in all of the settings above, I couldn't stop listening!
Most of listening is with the sv 811-10 with the back switch down and the filamentsin the 2.5 position. It is beautiful. If I want to impress someone with a big solidsoundstage that is dynamic and impressive I use the KR PX4.
Hi Vinnie,I just installed DAC 2.0 today. Like you said, I really love DAC 2.0. When I used DAC 1, though the detail, sound stage and image are better, the bass and atmosphere are not to the par comparing with analog output from my Rotel RCD 985BX (fully modified). However, with DAC 2.0, everything are brought up to a whole new realm. Detail is a lot better than the DAC 1. Sound stage expand wider with really ‘black’ background between the pinpointed image. Yet, there are more atmosphere. May be it due to the improvement on the low frequency, I guess. I don’t know how to explain the experience in English, since my English is not that good. We have a word in a Thai, ไพเราะ, may be you can use the google translate to get the meaning. I try to explain quite a bit. The over all sound quality pull me into the music. It made me excitedly pull one CD out after another. It made listening to the music more pleasurable.Best regards,Patapong
