0 Members and 2 Guests are viewing this topic. Read 324513 times.
That's fine. You can also connect it so both channels provide their current, to the single signal.
Finally finished my second Folsom.
Between the binding posts of each channel, cut out either a slot between them, or drill a hole large enough between them that there is a clear opening between them. The idea is not to open it up far enough to sacrifice the integrity of the hole, but just enough to stop a turn in the grounding from the balanced outputs by allowing the two fields to touch.
Nice job, Brad--really well done!Before using this amp, I was never much of a believer in 'improving your source gear'. I was in the 'but they're just ones and zeros' camp, pass the digits and let the DAC do its thing. Well, not anymore! I hear a huge difference when using a usb attached hard drive loaded with flac files/raspberry pi 2/volumio/allo DigiOne/BNC SPDIF/iFi 5 volt SMPS versus spinning discs through my Oppo BluRay (coax SPDIF) to the Folsom 7297. Sorry for the aside, but this is quite a testament to this amp, I think!Enjoy, Brad
Very nice! I have one small suggestions that is a minor upgrade. It shouldn't take you 5 month... Between the binding posts of each channel, cut out either a slot between them, or drill a hole large enough between them that there is a clear opening between them. The idea is not to open it up far enough to sacrifice the integrity of the hole, but just enough to stop a turn in the grounding from the balanced outputs by allowing the two fields to touch.
