0 Members and 1 Guest are viewing this topic. Read 10465 times.
Disk Doctor (pile) brushes. Regards,Andy
I use a cheap bristle paint brush cut down to make the bristles stiffer. It works well, is cheap, and cleanable.
I was in Music Direct the other day to buy a brush and the folks there recommended a roller instead. Bought something called the In The Groove Cleaner or something like that. Described as a better solution to a brush which will just push dust around and not get into the grooves as well. That said, haven't A/Bed myself. Just passing on that POV, FYI.
I use the Discwasher brush. It's designed to be used damp, and it's pad has a rounded profile, allowing it to be "rolled" while brushing to pick up even more dirt while having a lesser drag when cleaning on a moving table.It has a pile type micro bristles (very short) that get into the grooves. The fluid that comes with it is worthless.
Cheap, yes - but are you sure that the diameter of the bristles is small enough that they fit down into the grooves? Regards,Andy
I love the discwasher brush too...I usually use it dry, but sometimes when something is not being picked up, I will moisten the leading edge of the brush with pure water... it then picks up the recalcitrant left overs!Works like a charm. (but this is on records that have already been through my deep clean routine, and been treated with Last preservative)I have heard variable reports of the later iterations of the Discwasher brush... (primarily negative) - I don't have any idea of whether they are justified or not.bye for nowDavid
41 years of trials in pretty much proof. Others that have had problems are either using dry (I'd never put any dry brush on a record, ever!!!) or using a formula not friendly to vinyl.If you want to put static on your vinyl, then use a dry brush. Remember that frictions creates static electricity? A damp brush neutralizes static charges and it also acts as a bonding agent to pick up particles.
The best "wet" brush, hands down, with no equal, is unavailable. It's the Parastat by Ernie Watts, discontinued sometime in the 70's I believe. http://www.vinylengine.com/images/model/watts_manual_parastat.jpg
