0 Members and 1 Guest are viewing this topic. Read 10470 times.
If you want to put static on your vinyl, then use a dry brush. Remember that frictions creates static electricity? A damp brush neutralizes static charges and it also acts as a bonding agent to pick up particles.
I've attached a few pics for reference.........
Perhaps that "lint roller" thing from Music Direct may be worth a look into.
During this time I also decided to clean the record with some scotch tape. You know, like you'd use the sticky side to pick up some lint on a sports jacket.Well, the damn tape cleaned the record better then my discwasher brush. If I was at it a bit more, it would be really clean. The sticky of the tape can't get down into the grooves, but can adhere to any particles lodged in the groove.Perhaps that "lint roller" thing from Music Direct may be worth a look into.Wayner
Hence IMO the sticky tape and the MD 'lint roller' are pretty pointless methods to clean an LP. Regards,Andy
Andy,This is not true. The In the Groove roller does a great job of getting the dust out of the grooves. I listened to records cleaned with one at Woodsyi 's house and they were dead quiet. The In the Groove roller is made of a material that does get down into the grooves and cleans the dust particles and what else might be lurking down there.Laura
Thank you Laura, for that info. The 'In the Groove' roller is obviously more appropriate than some sticky tape. However, I'll stick with my Nitty Gritty, followed by a wipe before and after each side with a CF brush (which never picks up any dust! )Regards,Andy
I agree with you that it is more appropriate than sticky tape. I ordered one to try instead of my AudioQuest carbon fiber brush which I use before each play (after the record has been cleaned on my Loricraft). I have found that there can be some dust, mainly on the surface, of previously cleaned records.
But the point is, Wayner, the stylus never 'sees' the dust particles on the surface of the LP - it contacts the dust particles which are in the grooves.Hence IMO the sticky tape and the MD 'lint roller' are pretty pointless methods to clean an LP. You need something which will get down into the groove.Regards,Andy
30XWayner
I was discussing this thread with the wife, and out she comes with a 3M lint brush. Works fantastic! Roll it over the record, it sticks like a madman and all the debris is gone!
