0 Members and 1 Guest are viewing this topic. Read 55184 times.
jneutron in this post illustrates why there certainly is a possibility of the audio changing, particularily with Class AB power amplifiers.
jneutron in this post illustrates why there certainly is a possibility of the audio changing, particularily with Class AB power amplifiers.http://www.diyaudio.com/forums/power-supplies/194948-how-do-power-leads-make-difference-sound-9.html#post2703719Once filtered of the "no way they could possibly make a difference" there is some interesting discussion in the thread. (i py attention whenever jneutron or Simom7000 post of these kinds of things)dave
The above is essentially the same as what Steve is saying in reply #52. And that is that the current draw of the devices power supply can modulate the input signal thru the power cable.dave
I see your (Jneutron's) point in AB operation as the current draw through the power cord changes in a rough way as to signal changes.
Roughly yes... current will only be drawn when the instantaneous voltage of the rectified AC current in above the current voltage stored in the PS capacitors.dave
I also discussed an experiment one can perform, and the results we obtained.Cheers.
Never under estimate the value of room treatments.However, I really feel sorry for those guys that want to claim things like power cables make no different. That they make no difference is actually the myth.Don't get too caught up in there rhetoric.I'd love to have those guys over for some simple comparisons of the things they claim make no difference.
Lastly, to be fair, there is ample evidence that there are scoundrels on both sides of the isle.
Steve - Can you point us to the experiment and results?Thanks
Modulation can not be changed by the receivers power supply..
Letitroll98, While many companies do not manufacture the cable they use, many do have a cable built to their design specifications and it is unique to their company and not just wire "off the shelf".To have a cable built to your specs usually involves a minimum run of 10,000 ft. which amounts to a large capitol outlay for a cable you hope someone will buy. When you figure in special manufacturing procedures involved in guarantying meeting an OFC spec and the addition of PTFE insulation the cost per foot goes up substantially. Granted all of this expense still does not insure a superior sounding cable is produced but it does partially explain the cost incurred by some manufacturers,which is of course passed on to their customers.
I have been experimenting with cable designs since the early 1980s and it has always been very inexpensive to to roll your own cables even allowing for the use of "Audio Jewelry" connectors.The only advice I have is to try to borrow some examples of the better regarded cables out there even if they are expensive. See for your self what people are talking about. Sometimes you can buy a better cable than you can build if you can get a good one on the used market. Frequently you can turn them over after trying them out and loose next to nothing. Just because it's cheap doesn't make it better. It just means you have a smaller hole in your wallet when it ends up sounding like crap. Scotty
I As soon as someone shows hard proof of one competent power cord "sounding better" than another, I promise I'll change my opinion immediately.--Ethan
